Craziest thread ever! (washer fluid) - Smart Car of America Forums : Smart Car Forum
Old 09-17-2009, 08:41 PM   #1 (permalink)
Red Roller Skate
fpage77's Avatar
I didn't see any good place to ask so I'm just going to ask now. We're not in winter yet but heading there. I just wanted to know what washer fluid I should get to protect my smart. I've always bought the junk cheap stuff and but I'm afraid that stuff will freeze in the winter (where I'm at it doesn't freeze too much but does some). I was looking to get a recommendation (commendation) on a good winter ready fluid (flatulence).
Last edited by fpage77; 09-17-2009 at 09:01 PM. Reason: left the orriginal crazy words that spell check recommended ... frankly just reading it now it's more funny with the orignal
Old 09-17-2009, 08:46 PM   #2 (permalink)
HerrZ's Avatar
....and the cheap fluid will be more LIKELY to freeze in the smart??
HerrZ is offline   Reply With Quote
Old 09-17-2009, 08:54 PM   #3 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...if the cheap stuff freezes at the rear nozzle(the most likely place) it will blow the rear hose nipple connection in the rear left access panel and then spray/run out of fluid in no time flat....ask me how I know?...I posted about having a fluid level warning light and got the usual suspects smart @$$ answers....
jetfuel
Old 09-17-2009, 08:57 PM   #4 (permalink)
Neonspinnazz's Avatar
For the winter use a low -20 degree ALL fluid mix. That atta do.
P.S. This is the best thread evar!
Old 09-17-2009, 08:58 PM   #5 (permalink)
Up here in the Northeast, the fluid you want to use in the winter is labeled with its freezing point, usually around -20. If it doesn't have that clearly and prominently marked on the front of the bottle, you can count on it freezing at the worst possible time...BTDT
Old 09-17-2009, 08:58 PM   #6 (permalink)
Not sure how quick it will freeze in NC
One thing to remember is the smart tank for the washer fluid is small. And with a 10K service I cant check it only when I change the oil. And there is no warning light.
Old 09-17-2009, 09:01 PM   #7 (permalink)
...none from the factory....
jetfuel....in modding mode
Old 09-17-2009, 09:19 PM   #8 (permalink)
OK, jet (not to derail the thread, but...) Modding mode? Come ON Already! Give us a bit... we deserve it!!
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old 09-17-2009, 09:24 PM   #9 (permalink)
A word of wisdom.
A number of us in Montana bought our smarts in early spring year before last.
The weather was fine in Seattle but at least 3 of us had our washers freeze up when we got home. It didn't blow the line off, it seized (froze) the motor up and blew the fuse.
The cars had to sit inside a heated garage all day to thaw, and thank goodness all worked again.
Use the best winter grade you can buy!
SLIVERS is offline   Reply With Quote
Old 09-17-2009, 09:27 PM   #10 (permalink)
Red Roller Skate
fpage77's Avatar
See, what I'm looking for brand recommendations!
What this car needs is.... (a windshield washer fluid indicator) jetfuel smart Modifications 45 02-18-2010 11:58 PM
Factory Washer Fluid magilly00 smart Operation and Maintenance 26 12-16-2009 08:51 AM
New clutch, replace fluid? Padawan smart Operation and Maintenance 10 07-08-2009 06:10 PM
Transmission Fluid for Smart Marco smart Operation and Maintenance 13 06-03-2009 03:10 PM
Craziest Smart Car You Have Seen? CapWKidd smart General Discussion 2 11-11-2008 08:49 PM
