Originally Posted by RussBarnes
Rich,
Russ;
I'm just curious, I have a 450 and have the 34/78 Optima.
On the floor, about 4" from the old battery's NEG post, there is a 6mm stud that was where the NEG cable grounded to the chassis. On the floor about 4" to the right of the POS post is an identical stud protruding from the floor.
I just switched the NEG cable to the upper stud when installing the Optima.
My question is: does the 451 have the stud near the POS post like the 450 ?
BTW: The 'Robustness' of the Optima as opposed to the OEM battery is readily apparent.
Mine is almost two years old and shows NO signs of degradation.
Also, if you ever need warranty on the Optima, I'm pretty sure there will be a Optima dealer closer than a Smart dealer.
Cheers
Donald LaFavor
