Old 02-06-2009, 06:06 AM   #1 (permalink)
Docthrock's Avatar
Drive: passion comfort pack
Dead or Charge Battery & 3 line dash display
Just so everyone can find the information a little easier...
If you kill (or perhaps even disconnect for whatever reason) your battery, chances are that you are going to see the dreaded "3 lines (bars) of death" on your dash display. This is apparently normal/common in this instance, and there is a restart technique you follow to "reset the computer". That involves a sequence of key off, key on, run the shifter through the gears once or twice, key off, key back on. Thanks to the Evilution Encyclopaedia for this and a lot of other information.
Seems when I did this, I had to go rather slow and I heard a click. Maybe I get the click all the time. But it took me two or three tries to get rid of the three lines in the gear display on the dash.
One thing I noted when I disconnected the battery in order to charge it was that my positive terminal was not only somewhat loose, but there was a LOT of corrosion on the battery terminal. Those of you that may be experiencing weak batteries, or if you're a nervous nelly, might want to pull back the carpet and the battery panel and check your terminals for tightness and corrosion. Just saying...
Docthrock is offline   Reply With Quote
Old 02-06-2009, 07:41 AM   #2 (permalink)
Disconnected my battery several times and never had a problem with the transmission indicator remembering. Mine was always in park and not moved while battery was out.
Old 02-06-2009, 08:57 AM   #3 (permalink)
moderator
Dunerunner's Avatar
Drive: Yellow/Black Passion
Also posted in this thread FAQs/DIY: OPEN to see easy solutions to most common issues ...First post!
Old 02-06-2009, 12:29 PM   #4 (permalink)
Docthrock's Avatar
Thanks for that link. Regrettably when I SEARCHED and read MANY threads, that one didn't appear. Probably has something to do with titles and search keywords. Anyway, just trying to help.
Now I know how fast my battery will die if I leave the dome light ON. Duh.
Old 02-06-2009, 03:29 PM   #5 (permalink)
I too have disconnected the battery a number of times and never had a shifter problem when it was reconnected.
Old 02-06-2009, 03:55 PM   #6 (permalink)
Don't feed the Panda
Drive: 09 Red/Blk/Blk Passion
Originally Posted by Docthrock View Post
.....Now I know how fast my battery will die if I leave the dome light ON. Duh.
SSOOOOOO Doc,
HOW fast IS it
Old 02-07-2009, 05:16 AM   #7 (permalink)
Docthrock's Avatar
It was about 1.5 days when I checked the car. Maybe less. I wasn't driving the smart during "the blizzard", so it sat alone in the garage. If I hadn't needed to get something out of it to put in my other car, it could have been dead for days.
Who knows how weak the battery was to begin with, due to corrosion and a not so tight cable.
Dead Battery (incl. battery charging) cablvr Smart Car Operation and Maintenance 82 05-03-2009 08:18 PM
My battery is dead ............ Duckhunter The Car Lounge 3 01-29-2009 04:21 AM
Dead Battery jordman New Members Area 16 01-11-2009 01:15 PM
Insufficient charge - low battery Michael Hollar Smart Car Operation and Maintenance 7 04-23-2008 10:45 PM
