Disconnected battery - won't start! - Smart Car of America Forums : Smart Car Forum
Old 07-24-2008, 09:00 PM   #1 (permalink)
I disconnected my battery, and upon re-connection, the car will not start!!! HELP!?!?!??
Old 07-24-2008, 09:21 PM   #2 (permalink)
I hate to ask this, but did you follow proper procedure per the manual? It specifically says if you don't reconnect cables in the right sequence you can fry the ECU.
Old 07-24-2008, 09:29 PM   #3 (permalink)
Fixed it...
I called the 800-SMART-USA and they had me re-program the car (very easy) and now everything is great. Gotta love the customer service...
Old 07-24-2008, 09:32 PM   #4 (permalink)
ok, now I'm intrigued... what procedure did they tell you to use?
Old 07-24-2008, 10:18 PM   #5 (permalink)
reset
1. Push down and hold in brake
2. turn key to on (#1 position)
3. shift from P-R-N-D then manual mode (+/-) then back to D-N-R-P
4. turn key off
5. start car
I could hear movement in the engine compartment (going through the gears) and it worked. The CSR said that if you shut down the car and it isn't in P completely, then upon restart it won't work... this somehow reprograms the car electronically.
Hope this helps anyone else...
The Following 9 Users Say Thank You to graphix1998 For This Useful Post:
b322da (09-17-2011), fredp (07-18-2012), Kauna (11-20-2012), MarkMussatt (09-24-2012), Mr. Ed (03-25-2012), primostoy (10-23-2011), recyclerob (04-06-2012), ricla72 (07-13-2011), trfellows (07-17-2012)
Old 07-25-2008, 04:50 AM   #6 (permalink)
MichaelJ's Avatar
At what point in this sequence do you release the brake?
MichaelJ is offline   Reply With Quote
Old 07-25-2008, 05:53 AM   #7 (permalink)
Admin/Mod.
This thread has now been linked in the FAQs sticky folder...
Old 07-25-2008, 06:10 AM   #8 (permalink)
4. turn key off
5. start car
GREAT INFO!!! thanks for posting that. it may help others......
The Following User Says Thank You to Big Panda For This Useful Post:
recyclerob (06-04-2011)
Old 07-25-2008, 07:04 AM   #9 (permalink)
a2jack's Avatar
Graphix. Valuable post, Thankx. A2Jack
Old 07-25-2008, 07:34 AM   #10 (permalink)
orngandblack's Avatar
fyi,
Don't know if this means completely in any gear or just park, but I gotta tell ya that since I am use to driving a stick, I have on several occasions shut of my smart without putting it in park at all and have never had an issue with it not starting the next time.
orngandblack is offline   Reply With Quote
No start with new battery?! BrokenSmart smart Operation and Maintenance 45 11-12-2010 08:07 AM
Start after recharged dead battery astuto smart Operation and Maintenance 7 05-23-2010 05:37 PM
Start the car when key battery is dead gd220781 smart Operation and Maintenance 17 06-02-2009 06:25 PM
Dead Battery (incl. battery charging) cablvr smart Operation and Maintenance 82 05-03-2009 08:18 PM
(Re: low battery) Blinking wrench, -1, won't start rand76 smart Operation and Maintenance 11 02-06-2009 04:46 PM
