DIY gear shift removal and lube (short video) - Page 12 - Smart Car of America Forums : Smart Car Forum
LinkBack (15) Thread Tools Display Modes
Old 07-14-2009, 11:06 AM   #111 (permalink)
Dave777's Avatar
Anyone starting to have problems, or intermittent problems, should be going directly to the dealer, regardless of distance.
Old 07-14-2009, 05:28 PM   #112 (permalink)
Originally Posted by stressed member View Post
I think at the first sign of this problem I might just drill a hole in the top of the shifter ball and add a rod etc, to act directly on the T underneath.
Billet and Acrylic Fantasies sells a replacement shifter knob that essentially does that but looks a bit nicer. If you want to go that route, you can usually find them on eBay or go to their web site for their phone number and give Tom a call.
Old 01-09-2010, 05:03 PM   #113 (permalink)
GeekGirl's Avatar
Originally Posted by saronian View Post
This is a quick 90 second video I made while lubricating the shifter on my smart fortwo. Hope it helps others see how easy it is to do before you get stuck out on the road.
View a higher quality version on the YouTube website. Click here and then select "watch in high quality" below the video on YouTube.
Shifter Removal & Lube
thank you for posting that you
GeekGirl is offline   Reply With Quote
Old 09-06-2010, 04:49 PM   #114 (permalink)
mews's Avatar
Thanks for the help
My shifter got stuck and would only go to neutral or drive recently and by using this board and this thread in particular, I was able to use the silicone spray into the crack between the knob and rest and it immediately worked without having to take anything off. I was prepared to do the rest but thankfully didn't need to. Although I'm out of warranty, I plan to discuss this with the dealer as my car was one of the original ones with the bad shifter when imported. It was supposedly fixed before delivery but I'm disappointed to think it didn't last. Guess I will have to carry around the spray as part of my emergency equipment
mews is offline   Reply With Quote
Old 02-02-2011, 07:27 PM   #115 (permalink)
Shifter stuck
Thanks to all for the info. The last time this happened the dealer sold me a complete shifter assembly. $$$$$. I couldn't get the knob off tonight and just hosed it down with WD40. Got enough into the area to let the button lift the release. I'll pull it apart and do a complete job this weekend.
Someone deleted the pictures in the original post. Not good.
Thanks for the assist. Smart needs to recall these knobs and replace with a better design.
Wizzo is offline   Reply With Quote
Old 02-02-2011, 08:18 PM   #116 (permalink)
Did you see the video at Post #48? DIY gear shift removal and lube (short video)
Old 02-03-2011, 06:39 AM   #117 (permalink)
Got it. Thanks.
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f25/diy-gear-shift-removal-lube-short-video-5428/
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 11-14-2008 08:10 AM
transmission/shifter probems/failure - 451 smart fortwo This thread Refback 10-31-2008 01:22 AM
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 10-23-2008 07:05 AM
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 10-17-2008 07:56 PM
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 10-16-2008 12:58 PM
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 10-15-2008 10:43 PM
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 10-14-2008 08:48 AM
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 10-13-2008 08:56 PM
(not so smart) parking - smart USA insider This thread Refback 09-05-2008 11:05 PM
transmission/shifter probems/failure - 451 smart fortwo This thread Refback 07-23-2008 07:53 AM
transmission/shifter probems/failure - 451 smart fortwo This thread Refback 07-18-2008 03:46 PM
transmission/shifter probems/failure - 451 smart fortwo This thread Refback 07-16-2008 04:16 PM
transmission/shifter probems/failure - 451 smart fortwo This thread Refback 07-16-2008 02:26 PM
Automatice Shifter Problem - smart USA insider This thread Refback 06-18-2008 12:20 PM
Automatice Shifter Problem - smart USA insider This thread Refback 06-17-2008 11:33 AM
gear shift lever lperry New Members Area 13 03-01-2011 01:06 PM
smart in the shop: Gear shift lever stuck in N or D motten New York Chapter 2 07-07-2008 07:16 AM
Gear Shift Delay MicroNut smart General Discussion 12 11-11-2007 08:37 PM
Street Tour Short Video smartcar smart Gallery 0 07-11-2007 11:09 PM
