DIY gear shift removal and lube (short video) - Page 3 - Smart Car of America Forums : Smart Car Forum
LinkBack (15) Thread Tools Display Modes
Old 06-09-2008, 01:54 PM   #21 (permalink)
rwjrn's Avatar
I used a strap wrench to get the knob off easily without marring or any damage. You can pick these up just about anywhere for very cheap.
rwjrn is offline   Reply With Quote
Old 06-09-2008, 03:00 PM   #22 (permalink)
Did anyone come up with an answer for Quagmire's question: how do we remove the one-piece shifter?
Old 06-09-2008, 03:17 PM   #23 (permalink)
Dave777's Avatar
For what it's worth, when I look at my shifter it appears to be the one-piece style, without a separate collar. And yet, I can turn it that 1/8th turn CCW.
Old 06-09-2008, 03:20 PM   #24 (permalink)
smart y pants's Avatar
[B]Quagmire
I'm not sure your shifter is any different than the rest, if it is on a 451. I own a
Cabrio off the first boat 01/08 and the collar and curved collar base are all one piece as in the photos. The first time I tried to use pliers as shown in the photos it did not work, but turning it counter-clockwise with a clean, bare hand while lightly pulling up on the shifter knob it worked like a charm.
Hope this helps
smart y pants is offline   Reply With Quote
Old 06-09-2008, 03:56 PM   #25 (permalink)
Quagmire's Avatar
Hey guys I thought you forgot about me... I used one of these straps and it worked like a charm. Fortunately, I didn't have any problems with my shifter, but after spraying it with silicone spray it is much smoother. I think it is a wise move for everyone to do this process for piece of mind and so that hopefully you won't get stranded. ;)
Old 06-11-2008, 07:31 PM   #26 (permalink)
wlmory's Avatar
GREAT post, with pics to boot! Thanx, this place rocks w/ help and ideas!
wlmory is offline   Reply With Quote
Old 06-12-2008, 09:12 AM   #27 (permalink)
i liked the idea posted earler of tidying up the plastic piece with an emery board to remove any roughness from the molding process.
Old 06-16-2008, 02:19 PM   #28 (permalink)
My Passion convertible w/4K miles is from the first boatload also. I checked with my service technician at Herb Chambers in Somerville, MA. He knew all about the problem. He uses spray lube.
I sprayed a shot of white lithium grease (which I usually use on door and trunk hinges and latches) up into the knob and rubbed a little on the nylon "T". Now my shifter works fine again.
John Hosken is offline   Reply With Quote
Old 06-17-2008, 07:30 PM   #29 (permalink)
spray lube
I wonder how often you should lube the shifter, once a year, once a month?
Old 06-17-2008, 07:51 PM   #30 (permalink)
Quagmire's Avatar
I would suggest that as soon as you feel the shift button not moving silky smooth... hit it with the lube.
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f25/diy-gear-shift-removal-lube-short-video-5428/
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 11-14-2008 08:10 AM
transmission/shifter probems/failure - 451 smart fortwo This thread Refback 10-31-2008 01:22 AM
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 10-23-2008 07:05 AM
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 10-17-2008 07:56 PM
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 10-16-2008 12:58 PM
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 10-15-2008 10:43 PM
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 10-14-2008 08:48 AM
Carbon Fiber Parts for Smart Car - 451 smart fortwo This thread Refback 10-13-2008 08:56 PM
(not so smart) parking - smart USA insider This thread Refback 09-05-2008 11:05 PM
transmission/shifter probems/failure - 451 smart fortwo This thread Refback 07-23-2008 07:53 AM
transmission/shifter probems/failure - 451 smart fortwo This thread Refback 07-18-2008 03:46 PM
transmission/shifter probems/failure - 451 smart fortwo This thread Refback 07-16-2008 04:16 PM
transmission/shifter probems/failure - 451 smart fortwo This thread Refback 07-16-2008 02:26 PM
Automatice Shifter Problem - smart USA insider This thread Refback 06-18-2008 12:20 PM
Automatice Shifter Problem - smart USA insider This thread Refback 06-17-2008 11:33 AM
gear shift lever lperry New Members Area 13 03-01-2011 01:06 PM
smart in the shop: Gear shift lever stuck in N or D motten New York Chapter 2 07-07-2008 07:16 AM
Gear Shift Delay MicroNut smart General Discussion 12 11-11-2007 08:37 PM
Street Tour Short Video smartcar smart Gallery 0 07-11-2007 11:09 PM
