Originally Posted by earldahl
Do I have to use 0w-40? A friend of mine said i could use 5w-30 but i'm not sure
No. It is true that smartUSA has been using only 0W-40 for the VPC oil changes, but that is because the cars are then distributed to every climate in the country, a "one-size-fits-all" that may not be optimal everywhere. Refer to pg. 315 of your Operators Manual, which says "Using the chart below, select the oil viscosity according to the lowest air temperature expected befroe the next oil change."** Or, use the viscosity that competent service managers in your climate recommend.
** The '09, N.A. OpMan does not explain why the viscosity chart has been modified to truncate the upper range of 30-weights - the Euro manual doesn't, M-B doesn't, nor any other viscosity chart I can find. I'm not above believing that it is a smartUSA (Penske) subterfuge to lead people to shy away from common 30-weights in favor of less common 40-weights (just so happens that Mobil 1 0W-40 is readily found).
