Door Adjustment - Smart Car of America Forums : Smart Car Forum
Old 11-02-2009, 09:47 AM   #1 (permalink)
stressed member's Avatar
Door Adjustment
Had a rattley pass door. Adjusted passenger door latch loop ( it was one index mark from center) and noticed that the plate would not go past the center index mark. It fealt as if it was at the end of the slot in the body.Well, the door is certainly less rattley, but it seems , thats the end of the adjusting. Has anyone run into this?
stressed member is offline   Reply With Quote
Old 11-02-2009, 11:26 AM   #2 (permalink)
Owner for 3.8 years
Kermit's Avatar
If you're close enough to the dealer, make them fix it. If not, there is a plastic pin that is BEHIND the latch and that is what is stopping further adjustment. I imagine it is there for some reason.
That being said, I pulled mine and adjusted it....rattle gone but the door rides too close to the tridion for my liking.
Old 11-02-2009, 11:26 AM   #3 (permalink)
Admin/Mod.
Yes, I had this done by the dealer: about 2/3 a mark "in" to silent the rattle. It did work. As said, it was done by the Dealer.
Old 11-02-2009, 01:08 PM   #4 (permalink)
Ahhh, hidden stop pin eh? Thank you for the quick responses. It's bearable where it is for now. I,m sure it will get "depinned" in the future as the rubber shrinks or as whatever causes this progresses.
Old 11-02-2009, 01:13 PM   #5 (permalink)
Owner for 3.8 years
Kermit's Avatar
Yeah, I'd pull that pin as a last resort. Since my car is well out of warranty I don't mind doing occasional adjustments.
Valve adjustment Bykrdon smart Operation and Maintenance 21 12-25-2008 03:38 AM
smart Door Adjustment Gene_SD smart Operation and Maintenance 12 08-21-2008 04:21 PM
Steering Wheel Adjustment The Silver Pellet smart Operation and Maintenance 5 08-15-2008 03:44 AM
ScanGauge Adjustment Factors scronce Tech & Gadgets 4 06-15-2008 07:00 PM
Attitude Adjustment Springlering smart General Discussion 12 04-17-2008 04:03 PM
