Door won't stay open after service - Smart Car of America Forums : Smart Car Forum
It's alive...!
Old 04-21-2012, 04:24 PM   #1 (permalink)
sheureka's Avatar
I took my 2008 to a local shop on Friday for the 20,000 mile service. I didn't get the brake fluid changed but other than that they took care of everything and I was quite pleased with the work and the price.
Except - my driver's side door will no longer stay open. It used to stay open all the way and also at a halfway point, but now it closes all the way unless I physically hold it open. This is a real problem for me, since I have one nonfunctional leg that I need to sort of pick up and move in and out of the car. In the day I've had it back I've been propping the door open with my cane, but that's really inconvenient (particularly since I need the cane to stand up once I get out of the car).
Does anyone know what may have happened? Is there an easy adjustment? Or should I just take it back and have them see if they can fix it.
Thanks for any help - sheureka
Old 04-21-2012, 04:32 PM   #2 (permalink)
Smart Bob's Avatar
Door not propping open:
Looks like there is an issue with the door check. It could be the plastic roller disintegrated or the check itself is broken. You can look at the hinge on the drivers door and then check out the passenger door and see what is different.
Smart Bob is offline   Reply With Quote
Old 04-21-2012, 04:55 PM   #3 (permalink)
JOIN SCOA YOU'LL BE GLAD
...Sheureka..check and compare left and right doors as Bob said...if you don't know what they look like it is a white roller mounted at the end of a shaft with the hinge assy...
Jetfuel...let us know
The Following User Says Thank You to jetfuel For This Useful Post:
sheureka (04-24-2012)
Old 04-21-2012, 05:50 PM   #4 (permalink)
Brabus007's Avatar
YUP, the Bas-Tards broke it...
Scroll down this link to see and read about it...Door Hinge
Rear Tailgate Lower Hinge Failure
Old 04-22-2012, 07:12 AM   #5 (permalink)
I tried to put a red circle around the roller on a picture from SmartJoe. It's still hard to see the roller but it might help you find it:
The Following User Says Thank You to mvaldes For This Useful Post:
Old 04-22-2012, 08:55 AM   #6 (permalink)
a2jack's Avatar
Or maybe thay just lubed it. A2Jack.
a2jack is online now   Reply With Quote
Old 04-24-2012, 11:42 AM   #7 (permalink)
sheureka's Avatar
I finally looked at the other door and something is definitely missing on the driver's side. Does anyone know if that piece is reversible, i.e., could I take the passenger's side stop out and put it on the driver's side? I seldom have passengers so it doesn't matter that much with that side. If it can't be switched any idea of how to get this fixed or where to get the part? TIA - sheureka
Old 04-24-2012, 11:53 AM   #8 (permalink)
Start at post 46 in this thread for a DIY fix. Problem with door hinge - anyone else?
Door won't shut! unicycle smart General Discussion 52 03-01-2013 08:53 AM
Doors won't lock...hatch won't open! (bad door actuator) fredp smart Operation and Maintenance 31 04-27-2012 07:18 AM
License plate won't stay in mnext02 smart General Discussion 8 09-01-2010 06:36 AM
Anyone open the inside of the glove door itself? donnyonee Interior & Exterior 2 04-11-2010 09:31 AM
Rear Window (won't open) burtandnancy smart Operation and Maintenance 10 01-17-2010 05:13 AM
