Doors seem loose! - Smart Car of America Forums : Smart Car Forum
Old 01-27-2009, 09:30 PM   #1 (permalink)
greatfoxmusic's Avatar
Doors seem loose!
Hello all,
My smartie has been developing some small rattles and noises since I got it, which is not surprising given the bad roads I have to drive on. However what is making me a little nervous is my doors, especially my driver's side door, rattles on the latch when I hit bumps. When I go off camber on a large bump, like a railroad track at an angle to the road.. big time latch noise, like the doors are about to fly open!
Anyone else getting this, and is there a way to tighten the doors so they latch more securely?
I just keep remembering the crash test where the door flies open after the crash, I wonder if that's the same issue.
Thanks
--Todd
greatfoxmusic is offline   Reply With Quote
Old 01-27-2009, 09:32 PM   #2 (permalink)
For sale pm for details
Turbo42's Avatar
my latch also makes noise when going over bumps has done it since i got it
Old 01-27-2009, 10:28 PM   #3 (permalink)
Quagmire's Avatar
Grease the latch area with a Q-tip and you will have silence
Old 01-28-2009, 02:24 AM   #4 (permalink)
Admin/Mod.
Same here: it sounds as if the doors are brushing against the seals and squeak while driving on major bumps. But I do attribute this to the cold winter weather. Any suggestion as to rubber lubricant?
Old 01-28-2009, 05:16 AM   #5 (permalink)
Owner for 3.8 years
Kermit's Avatar
I have the same problem - grease won't cure that 1/8-1/4 of an inch that I can jiggle the door when I push on it from the outside or pull from the inside. An adjustment is in my future I think.....
Old 01-28-2009, 05:28 AM   #6 (permalink)
Padawan's Avatar
Adjusting the latch is pretty straightforward. If you look at it closely (the part on the car, not on the door), you'll notice there are a series of lines along each edge of the latch, as well as individual indicator lines on the Tridion. To adjust, you just loosen the screws, move the latch in the direction it has to go, then tighten the screws again. The lines will help you keep track of how much you've moved it and in which direction.
Old 01-28-2009, 06:02 AM   #7 (permalink)
Owner for 3.8 years
Kermit's Avatar
Originally Posted by Padawan View Post
Adjusting the latch is pretty straightforward..........
What about the plastic pin? I have a pin that keeps it from going in any direction. I have actually adjusted my driver's door once already and the pin had to be removed to moved the latch in any direction.
Am I missing something?
Old 01-28-2009, 06:18 AM   #8 (permalink)
I actually just talked to the service manager about this (just the driver side on mine). He said it's a quick easy fix, and I'll be getting it done on Friday. I can let you know what he does (I live 10min from my smart dealer so I see no reason to do anything myself).
markitect is offline   Reply With Quote
Old 01-28-2009, 07:08 AM   #9 (permalink)
Padawan's Avatar
Are you talking about the latch in the door, or the metal latch/striker attached to the Tridion? The latter is what is adjustable.
Old 01-28-2009, 10:41 AM   #10 (permalink)
Owner for 3.8 years
Kermit's Avatar
Tridion.......the one with the marks for adjusting. There is a plastic "alignment?" pin in a hole.
Probably going to loose my reservation due to Brabus Option yellow smart smart General Discussion 14 01-13-2009 09:53 AM
Loose Gas Cap = Check Engine Light foxmajik smart Operation and Maintenance 4 11-19-2008 02:54 PM
P0455 scanguage code - loose gas cap smartokie smart Operation and Maintenance 2 10-07-2008 11:39 AM
Loose center caps on wheels Quagmire smart General Discussion 2 09-23-2008 06:11 PM
Vibration = Loose roof in Passion 424me smart General Discussion 1 09-11-2008 03:20 AM
