Doors seem loose! - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 01-28-2009, 11:29 AM   #11 (permalink)
Padawan's Avatar
Originally Posted by Bum-bling-B View Post
Tridion.......the one with the marks for adjusting. There is a plastic "alignment?" pin in a hole.
Hmm... I'll have to take another look when it's not snowing or 20 degrees outside.
Is the plastic pin beneath the metal striker? The only thing visible to me were the two large metal screws.
Padawan is online now   Reply With Quote
Old 01-28-2009, 12:50 PM   #12 (permalink)
Owner for 3.8 years
Kermit's Avatar
I may snap a picture later this evening......oh and today is a shorts day here, shorts AND A/C use.
Old 01-28-2009, 01:23 PM   #13 (permalink)
Mom liked you better
The Rigger's Avatar
Originally Posted by JPaul View Post
Any suggestion as to rubber lubricant?
For what, the door seals?
Once upon a time, about a skillion years ago, when I worked in the auto-aftermarket goodies installation business (stereos, sunroofs, &c.) we had a "grease stick" we'd use on leaking sunroof and door glass seals; sort of an overgrown Chapstick lookin' thingummy made of silicone grease, that we'd apply to the seals to rejuvinate them. Dunno what rubber you're looking to lube, and I suspect this wouldn't help with rattling doors - that sounds more like a striker adjustment needs to be made - but I'll throw the info out FWIW. Maybe a glass shop or sunroof installer near you still has something like this.
Old 01-28-2009, 09:36 PM   #14 (permalink)
greatfoxmusic's Avatar
Heck yeah, someone take pics!
I want to adjust mine.
I should also silicone spray my gaskets...
greatfoxmusic is offline   Reply With Quote
Old 02-01-2009, 04:28 PM   #15 (permalink)
The dealer told me this was a common problem. The service manager took care of it and another problem in about 25 min. It appears that the latch part on the trident can be adjusted. And they simply loosened the bolts and moved it towards the interior of the car. They may have done something similar by the hinges too.
markitect is offline   Reply With Quote
Old 02-01-2009, 05:54 PM   #16 (permalink)
smark's Avatar
I took my car in for this issue, back in November. The service manager rub some kind of Mercedes-Benz white wax around the door seals, and tail gate seals. It worked fine till the first washing. There is door flex, because doors are made of plastic, and light a weight steel frame. The window rubs against the door seals, making the door rattle. It really bad in cold weather. When it warms up, it goes away. If your not near a dealer, rub some silicone lubricant, around the door seals. The seals get hard in the cold. He looked at my latches, and there was nothing wrong with them. Common issues.
Old 02-01-2009, 06:20 PM   #17 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...don't wait until the stuff fails...it's called preventive maintenance...
...this worked for me for many years....I wish you could see my 16 year old seals of my car....it does the trick...you may have a different product you like, but whatever it is, use it...
jetfuel
Old 02-01-2009, 07:57 PM   #18 (permalink)
Owner for 3.8 years
Kermit's Avatar
jetfuel - Amsoil!!! !!!
I'm a huge fan of Amsoil!!
Mine did the same thing they are doing now back in August and September. In Florida that means ***hot***. I hope you have better luck with those rattles once the weather gets warm smark.
In my particular cars; I do drive them down some bumpy dirt roads which amplifies pretty much any rattle that may be about to start.
The smart is still a great car - no complaints here! Rattles or not.
Probably going to loose my reservation due to Brabus Option yellow smart smart General Discussion 14 01-13-2009 09:53 AM
Loose Gas Cap = Check Engine Light foxmajik smart Operation and Maintenance 4 11-19-2008 02:54 PM
P0455 scanguage code - loose gas cap smartokie smart Operation and Maintenance 2 10-07-2008 11:39 AM
Loose center caps on wheels Quagmire smart General Discussion 2 09-23-2008 06:11 PM
Vibration = Loose roof in Passion 424me smart General Discussion 1 09-11-2008 03:20 AM
