Engine compartment cover - Page 3 - Smart Car of America Forums : Smart Car Forum
Trailer
Old 05-15-2008, 02:51 PM   #21 (permalink)
3 arms
Hay guys,
My smart has the little hook in the upper right hand corner of the carpet .
This is almost impossible to hook up.
I was going to spring the S hook open a little more but it is hard plastic
with no spring to it.
It is very hard to get hooked &
when you do you have to use vice grips to get unhooked
Not good huh?
smartysmitten is offline   Reply With Quote
Old 05-15-2008, 03:48 PM   #22 (permalink)
dbwill's Avatar
Easy, and you can use 2 hands, one for the dip stick and one to wipe it off.
Old 05-15-2008, 04:02 PM   #23 (permalink)
More on engine cover screw. I called my dealer, who told me that new (and presumably improved) screws are expected Monday.
GPfeffermann is offline   Reply With Quote
Old 05-15-2008, 04:07 PM   #24 (permalink)
saronian's Avatar
Thanks DBWill! That's too easy
Old 05-15-2008, 04:13 PM   #25 (permalink)
Admin/Mod.
dwill, thanks. It's simply smart. ;) Even the cover has the adequate profile...
Old 05-17-2008, 11:23 AM   #26 (permalink)
Used plyers
I ended up using a pair of plyers to turn the D-shaped black plastic piece in top of the key clockwise, and it did lock without breaking. I shall still be getting a replacement.
Guy
Old 05-17-2008, 11:27 AM   #27 (permalink)
MichaelJ's Avatar
Originally Posted by jonnysan View Post
...showing the engine cover Zeus fastener.
That's Dzus (pronounced like Zeus)
MichaelJ is offline   Reply With Quote
Old 05-17-2008, 03:59 PM   #28 (permalink)
mike-in-sa's Avatar
I found that if the dzus fasteners were hard to turn then the lid was not alligned right. When the lid is seated properly the fasteners work easy.
Old 05-17-2008, 06:24 PM   #29 (permalink)
esrazor's Avatar
My car doesn't have the carpet hook in the upper right corner. I have an empty hole there. The cargo cover goes into the area where the clip should be. Any ideas?
esrazor is offline   Reply With Quote
Old 05-18-2008, 02:20 PM   #30 (permalink)
I had an issue closing mine a couple times until I found that the "key" rotates 360 in the fitting. The next time I had problems with it, I lifted the cover, rotated the key 180, and then tried again, and it latched without a problem! I think it may be the key wants to be in a certain orientation when it starts? Can't hurt to try it if yours is hard to close next time you open it!
Worthwhile accessory: trunk cover stevenvillatoro smart General Discussion 21 06-30-2011 03:33 AM
Car Cover rwcmick smart General Discussion 44 03-04-2008 08:46 AM
Engine Revs GliderDude smart General Discussion 6 02-09-2008 07:09 PM
We make the cover of Forbes Life! Carnut smart News & Rumors 0 11-29-2007 06:09 PM
Mitsu Engine. a2jack smart Gallery 11 11-16-2007 02:12 PM
