Old 07-22-2008, 05:04 AM   #1 (permalink)
engine compartment cover latch
I was checking my oil & to reattach the engine compartment cover, the little turn button latch for the cover came out of its hole, won't seem to re engage to really snug engine cover down- is there a trick to this that I don't know?
roscoe is offline   Reply With Quote
Old 07-22-2008, 05:13 AM   #2 (permalink)
No trick; just make sure you have the two slots on the rear of the cover lined up properly and the cover is back as far as it will go.
Old 07-22-2008, 05:39 AM   #3 (permalink)
smart happens here!
SmartCard's Avatar
Drive: Red/Bk Cabrio, '04 JCW MCS
what he said.....seems to be the most important factor in getting it to catch!
Old 07-22-2008, 05:41 AM   #4 (permalink)
i thought itd be forward as far as itd go?
Old 07-22-2008, 05:54 AM   #5 (permalink)
IcePlanet's Avatar
Drive: Smart Cabriolet
I used pliers to help latch it. The two teeth on the nut can break off. The dealer has extras.
IcePlanet is offline   Reply With Quote
Old 07-22-2008, 06:07 AM   #6 (permalink)
Mod./Adm.
Drive: w/s/r '08 passion
Indeed, push fore as much as possible, at a rather low angle. A bit like a wireless phone or a tv zapper battery cover (bigger though!).
Old 07-22-2008, 06:08 AM   #7 (permalink)
smart happens here!
SmartCard's Avatar
when you lift it open, the cover has a tendency to slide towards the rear of the car, disengaging from the tabs...so quite often its needs to be pushed back (forward to the front)
Old 07-22-2008, 09:05 AM   #8 (permalink)
Not Selling on Ebay
Drive: 2006 Mini CVT
Latching will become easier each time it is done.
Old 07-23-2008, 05:57 AM   #9 (permalink)
I guess I wasn't clear- the little turn button comes out of the hole, like its broken off something; can't get it to engage and stay attached to the rest of the structure when I reinsert it & turn. Will seem to start to engage but can't get it it to stay, it want to rotate back towards left and pops free- is it busted? I guess I'm not the most articulate poster...
Old 07-23-2008, 06:16 AM   #10 (permalink)
Mod./Adm.
Just went down to look at it again.
The thread of the peg is such that it requires only 1/4 turn clockwise to latch. The peg seems to be made of soft alloy, prone to get worn - and its plastic D-ring broken - if the peg and the receiving hole are not aligned.
In your case, it sounds like the peg has gotten lose from the cover. Is it possible to re-insert the peg in the cover?
Rear Window Latch Problem CliffK Smart Car General Discussion 19 10-31-2009 07:26 PM
engine cover muleguy Smart Car Operation and Maintenance 19 07-14-2008 12:33 PM
Tailgate window latch issue Kidbyte Interior & Exterior 19 06-24-2008 09:32 AM
Engine compartment cover riversidesmart Smart Car Operation and Maintenance 34 05-27-2008 08:39 PM
Help w/Engine Compartment Cover redbluff Smart Car Operation and Maintenance 7 03-31-2008 03:09 AM
