engine compartment cover latch - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 07-23-2008, 07:22 AM   #11 (permalink)
I can put it in, but it wont stay,just rattles around loose
roscoe is offline   Reply With Quote
Old 07-23-2008, 07:28 AM   #12 (permalink)
Admin/Mod.
Yes, the peg is loose and wiggles! The "art" of getting it to latch is to align the peg and its hole in the engine opening's frame. The foam holds the cover a little above its tight closed location. Align the peg with the whole, push on the cover and turn ever so lightly the peg clockwise only a quarter turn: it should grip.
And keep us (me) posted...
Old 07-23-2008, 07:39 AM   #13 (permalink)
i'll give it a try..thx! but when I mean the 'reg' and turnbutton are loose, I can take it out & put it in my pocket.
Old 07-23-2008, 07:48 AM   #14 (permalink)
banned
We had the same problem when we picked up our Smart.
There is a small aluminum clip that the latch catches onto. The clip can easily strip and needs to be replaced. You dealer can order the part. It only took 5 weeks for ours to come in...
Old 07-23-2008, 08:06 AM   #15 (permalink)
worst.
design.
ever.
Old 07-23-2008, 09:09 AM   #16 (permalink)
I think the latch is the more trivial issue here.
The heat issue is what really bugs me. Despite the thick insulation, I can still feel some heat through the top of the carpet. If you have groceries, you will realize the contents are slightly heated up after a bit of driving.
The cover is hardly insulated except for that pathetic rubber edge trim. I am looking into adding more thermal insulation.
Old 07-23-2008, 09:12 AM   #17 (permalink)
vince, something like this.
Heat shield
Old 07-23-2008, 09:30 AM   #18 (permalink)
That or polyurethane foam.
So do you "feel" the heat in your smart trunk?
Old 07-23-2008, 09:41 AM   #19 (permalink)
it was more pronounced before i put in the rear cocomat.
Old 07-24-2008, 08:57 PM   #20 (permalink)
Dan500's Avatar
It would be nice if an aftermarket vendor(hint,hint) could come up with an all metal "peg". I`m always worried the plastic knob will break off on me one of these days!
Dan500 is offline   Reply With Quote
Rear Window Latch Problem CliffK smart General Discussion 32 06-20-2010 05:41 AM
engine cover muleguy smart Operation and Maintenance 19 07-14-2008 01:33 PM
Tailgate window latch issue Kidbyte Interior & Exterior 19 06-24-2008 10:32 AM
Engine compartment cover riversidesmart smart Operation and Maintenance 34 05-27-2008 09:39 PM
Help w/Engine Compartment Cover redbluff smart Operation and Maintenance 7 03-31-2008 04:09 AM
