engine compartment cover latch - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 07-25-2008, 10:08 AM   #21 (permalink)
It's called a captive fastener. Any good hardstore should have it. McMaster and Grainger should have them in bulkThe only thing is the thumb piece is not foldable. In which case, a knurled head piece should work (bottom).
Old 07-25-2008, 11:31 AM   #22 (permalink)
Admin/Mod.
Thank you VinceLA!
Just one more question: the thread of those two examples are not the same than the one the smart has. Any technical description of the one we could use? To facilitate our search at the hardware store?
Old 07-27-2008, 07:11 AM   #23 (permalink)
While lining up the tabs and pushing the cover as far forward as possible is important, I have found that if you just push down while turning the latch AND AT THE SAME TIME give the cover a good firm bump with the side of your fist, the cover latches every time easily. If the latch and clip are already too worn from previous forced attempts, they may need to be replaced. The problem was so common that my dealership now stocks both the clip and the fastener.
SmarTek-TNG is offline   Reply With Quote
Old 07-31-2008, 11:04 AM   #24 (permalink)
Originally Posted by JPaul View Post
Thank you VinceLA!
I thought I subscribed to this thread...pardon the lack of response JP!
I haven't ordered them from mcmaster or scout the local homedepots for sizes. I haven't really got a problem with the factory piece. But what you can do is measure the diameter/length of the factory piece. Then see if you can find something close enough.
Originally Posted by rawlus® View Post
vince, something like this.
Heat shield
Guess what...I covered my engine with a 1.5" thick polyurethane foam (between compartment cover and top of engine). Less noise from the engine compartment and little to no heat transfer. I touched my trunk carpeting. It's not warmed up at all.
Old 08-07-2010, 03:27 PM   #25 (permalink)
jmaxwell38930's Avatar
Any way to keep it from falling off?
We accidentally dropped our latch pin into the engine, and had a difficult time finding it. Is there a practical way to attach it to the engine cover so that it doesn't come loose when the cover is off?
jmaxwell38930 is offline   Reply With Quote
Old 08-07-2010, 04:27 PM   #26 (permalink)
RallyRedY2KX's Avatar
If it came off ...... there is a retainer than holds it in place when you open the top. You used too much force to lift the lid .. look for the retain, it presses on from below to hole the peg in place.
RallyRedY2KX is offline   Reply With Quote
Old 08-07-2010, 04:38 PM   #27 (permalink)
JOIN SCOA.YOU'LL BE GLAD
..hey 930...if you already found the latch and you want to go the cheap way try this...cut a 1/2" round piece of plastic...milk jugs are a great source...punch a very small hole in center...a nail will do the trick...use this piece as the back up ring that will hold the latch in place after you force it onto the latch...
jetfuel...cheap skate..
Old 08-07-2010, 07:40 PM   #28 (permalink)
RallyRed, I don't remember ever seeing any sort of a retainer. I think the previous owner may have lost it. I bought the car 2nd hand.
Old 08-07-2010, 07:44 PM   #29 (permalink)
Thanks for the tip. But won't the milk jug plastic melt? It gets awfully hot in my engine compartment. I may need to look for another material.
Old 08-07-2010, 08:12 PM   #30 (permalink)
..our plastic retainer is 2 years old....
jetfuel...low fat
Rear Window Latch Problem CliffK smart General Discussion 32 06-20-2010 05:41 AM
engine cover muleguy smart Operation and Maintenance 19 07-14-2008 01:33 PM
Tailgate window latch issue Kidbyte Interior & Exterior 19 06-24-2008 10:32 AM
Engine compartment cover riversidesmart smart Operation and Maintenance 34 05-27-2008 09:39 PM
Help w/Engine Compartment Cover redbluff smart Operation and Maintenance 7 03-31-2008 04:09 AM
