engine cover - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 07-08-2008, 07:26 AM   #11 (permalink)
stevenvillatoro's Avatar
When I got my smart back in January, it took me an extra 45 minutes to get off the lot, because I opened the engine cover and then couldn't get it to lock. A technician replaced the latch, but it had the same problem. The solution turned out to be as simple as applying strong downward pressure at the latch point, and then twist. It was not a matter of 'seating' the cover properly, and could not be resolved by wiggling the cover, in my case.
Old 07-08-2008, 08:01 AM   #12 (permalink)
nscaler's Avatar
When I got my car, Ricardo was showing how to open the cover. He couldn't close it though. He pulled another set out of his pocket and switched the key and socket. Works fine since then.
nscaler is offline   Reply With Quote
Old 07-08-2008, 08:03 AM   #13 (permalink)
bull8042's Avatar
OK, maybe I should have prefaced my post with "here is what I have found"....
Old 07-08-2008, 08:15 AM   #14 (permalink)
Admin/Mod.
Originally Posted by bull8042 View Post
Forcing is not necessary, new gasket or not. Slide the cover forward such that the slot is under the ears and turn the latch. If it won't latch fairly easily, wiggle the cover side-to-side slightly and you will feel it "pop" toward the front of the car. Hard to explain, but if the latch is difficult to turn, the cover is NOT in the right place, regardless of how it appears...
I'd say it's a bit like a cell phone battery cover: the lid requires to be pushed into its groove all the way forward before closing it fully, then the D-ring screw and its hole should align.
Old 07-08-2008, 08:19 AM   #15 (permalink)
bull8042's Avatar
Originally Posted by JPaul View Post
I'd say it's a bit like a cell phone battery cover:...
And not much bigger!
Old 07-08-2008, 08:23 AM   #16 (permalink)
Owner for 3.8 years
Kermit's Avatar
EXACTLY, I'm familiar enough with the engine cover to know if it is properly centered. String downward pressure wasn't enough, that's why we applied SUPER strong downward pressure and it locked right into place.
Old 07-08-2008, 09:45 PM   #17 (permalink)
IcePlanet's Avatar
Mine broke when I was trying to lock it. The nut part broke, not the finger twist top. I went to the dealer and he said that a lot of them are breaking. They were out of them when I went the first time but they had a bunch on order. Went back a few weeks later and got it replaced. I only live 3 miles from the dealer so it wasn't a big deal. He said they MIGHT change the engine cover lock design on the 2009 model.
IcePlanet is offline   Reply With Quote
Old 07-08-2008, 09:54 PM   #18 (permalink)
I didn't get mine quite centered and twisted off the last 1/8" of the key (which the sales person had me use at the dealership). I also then realized that the alignment had to be just so to fully engage. I bought a cheapie circular screwdriver at Sears which is like a flat disc with flat blade protrusions of various sizes on the circumference. I just lay it on top of the engine cover under the carpet. Can't tell it's there and it doesn't get lost.
Belleveu1 is offline   Reply With Quote
Old 07-13-2008, 09:22 PM   #19 (permalink)
had the same problem with mine....and it's not pleasant if the engine is still hot. This worked for me. Slide the little clip-nut back until it is seated all the way back and centered in the hole. Then spray both the clip and the twisty thing with silicone spray. Don't know how permanent it will be, but it is a quick-fix. I agree, it's a poorly engineered system that should be redesigned
shop hermit is offline   Reply With Quote
Old 07-14-2008, 01:33 PM   #20 (permalink)
I bought a nut washer at the hardware store to replace the plastic one, then I put some vaseline one the shaft. It now closes and latches easily.
arude is offline   Reply With Quote
Engine compartment cover riversidesmart smart Operation and Maintenance 34 05-27-2008 09:39 PM
My car on cover of Car and Driver dcrooks smart News & Rumors 13 04-04-2008 08:32 PM
Help w/Engine Compartment Cover redbluff smart Operation and Maintenance 7 03-31-2008 04:09 AM
Car Cover rwcmick smart General Discussion 44 03-04-2008 08:46 AM
