Engine removal to change plugs? - Smart Car of America Forums : Smart Car Forum
Old 05-30-2008, 12:05 PM   #1 (permalink)
I just read on another thread that the engine must be removed to change the plugs, and that this is part of the 30,000 service. Even Chevys have 100K plugs now, so needing replacement at 30K is stupid. But dropping the engine to have to do it is even dumber.
When you add in the premium gas requirement, the cents per mile of the smart is starting to look higher than a large number of alternatives.
Does the engine have to be dropped to change the plugs?
cosmart is offline   Reply With Quote
Old 05-30-2008, 12:28 PM   #2 (permalink)
Founder/former Admin.
SMART's Avatar
Was this stated for the 450 or 451? Can you share the link with us?
Old 05-30-2008, 12:47 PM   #3 (permalink)
is it true that the euro smartcars get 60mph? If I get one is it legal in U.S.A If it is changed in the US why?
bbrandt is offline   Reply With Quote
Old 05-30-2008, 01:31 PM   #4 (permalink)
sight!!! read your manual please.
cosmart:
Remove the rear panel,
Use a heat shield tool from Mercedes to remove the shields, I have the part number.
A6385810267.
Replace plugs with OEM only. tighten to 22.5Nm
Reinstall shields
Reinstall rear panel,
it took me 30 minutes to do.
bbrandt
Yes, the European model fortwo 1999 til 2002 gave 500 km to a tank. still about 55mpg. Due to smaller engine 599cc and a smaller tank, also it had a 6th gear, lower rpm's meand lower revs and less gas.
and Yes, you can smuggle a 450 smart from canada or mexico, just don't get caught, the EPA has stiffer fines than state laws. you can probably get away with arm robbery better than EPA emmission violations.
Now go change your diaper....
oldmike is offline   Reply With Quote
Old 05-30-2008, 02:44 PM   #5 (permalink)
skyzdlimit59's Avatar
There is a thread somewhere here where there are pictures and step by step instructions posted on how to do it without removing the engine.
Old 05-30-2008, 06:06 PM   #6 (permalink)
Valve adjustment will require engine removal...........
saskdiesel is offline   Reply With Quote
Old 05-30-2008, 06:16 PM   #7 (permalink)
Fredvon4's Avatar
Spark plug change out proces is not in the 451 manua
There are NO heat shields to remove
The smart techs were trained that the power pack must be lowered to properly replace the plugs
I proved to myself that they come out and go back in just fine with the motor in place
The plugs get replaced a 30,000 and they are not iridum or platinum tipped..
For What It is worth I have never seen a 100,000 mile plug that was any good after 50,000 miles
I posted a thread about plug changing with a few crummy photos
http://www.smartcarofamerica.com/for...ug-change.html
Old 06-30-2011, 06:18 PM   #8 (permalink)
Admin/Mod.
'smallcarguy' post about the location of the radiator — and the responses — have been moved to their own thread:
Radiator's location
Old 06-30-2011, 07:16 PM   #9 (permalink)
Turboed Orange Crate
BARNEY O's Avatar
Nah, but you might want to take the wheels off first , it gets the car closer to the ground and easier to reach over the tailgate...
Old 06-30-2011, 09:57 PM   #10 (permalink)
SmartDigger's Avatar
you all are ansering a 3+ year old post.
Pulstar plugs...really increase MPG MarkB smart General Discussion 40 04-12-2010 07:05 PM
Why change engine and transmission oil soon crepatas smart Operation and Maintenance 82 06-19-2008 12:13 PM
451 spark plugs jwight smart Operation and Maintenance 20 02-07-2008 05:47 PM
Part #s for filters, plugs & pad/shoes jwight smart Operation and Maintenance 2 01-22-2008 07:38 AM
