EVAP temp sensor in the right pass footwell - Smart Car of America Forums : Smart Car Forum
Old 11-09-2009, 09:22 AM   #1 (permalink)
Have seen several references to this, and unplugging it to see if it improves A/C performance (after plugging it back in.) Where exactly is it located and how do you identify it (don't want to unplug the wrong item.) Thanks!
Old 11-09-2009, 11:32 AM   #2 (permalink)
If you put something on the "shelf" up above the battery, my understanding is you're in danger of damaging the fine wires from this sensor on the left hand side of that cubby area.
There's a picture somewhere in one of the threads. But where?
Old 11-09-2009, 11:49 AM   #3 (permalink)
JOIN SCOA.YOU'LL BE GLAD
just deleted my picture of the temp sensor ..sorry...green and brown and other color wires on a white plug..
jetfuel...all I got
Old 11-09-2009, 11:49 AM   #4 (permalink)
fastturb's Avatar
I may have read or interpreted your words wrong, but I don't think it is a unplugging and re-plugging in a way to reset something other than to really make sure the connection is good, secure and clean. It may have been hit, could be on loosely or even worse the sensor could be broken/damaged.
If the connection for whatever reason is bad, the outlet air won't get cold.
Old 11-09-2009, 11:53 AM   #5 (permalink)
Cool (or not, as the case may be) - so where is it and what does it look like?
Old 11-09-2009, 11:57 AM   #6 (permalink)
fastturb's Avatar
as stated above, look up on the passenger side under the dash to the left side - quite thin wires going into a sensor pointed left towards the driver pedals. You can't miss it - even my wife knows where it is and can show you - ask me why
Speed sensor, reverse sensor wires nemo1 Audio & Video 29 09-11-2011 06:39 AM
Tach, Oil temp and water temp in one gusfraga smart General Discussion 2 09-15-2009 11:46 PM
96 Cougar aip temp sensor ? Risewithfallen The Car Lounge 6 11-18-2008 06:13 PM
Oil Temp and Coolant Temp Gauge Install VinceLA smart Modifications 22 07-23-2008 09:00 AM
How hard is it to install light sensor or rain sensor? lukerc smart Operation and Maintenance 1 06-05-2008 07:52 PM
