Exhaust manifold torque specs - Smart Car of America Forums : Smart Car Forum
Old 10-24-2009, 12:14 PM   #1 (permalink)
GHammerly's Avatar
I'm planing to remove the whole exhaust system to take a look and see if it can be cleaned off a little for better flow, and to paint it.
Any one here know the torque spec for the exhaust manifold nuts?
Old 10-24-2009, 12:59 PM   #2 (permalink)
JOIN SCOA.YOU'LL BE GLAD
...I'll say go with AC-4313-1A for standard torque specs for specific thread size..and if nobody has the value then German torque will probably do it...GoodNtight...
jetfuel...calibrated elbow last week
Old 10-24-2009, 02:04 PM   #3 (permalink)
GHammerly's Avatar
Yeah, if no one comes up with info from a smart manual that's the back up plan.
I think it would be useful for the site to have a fairly comprehensive torque spec sticky. I'm not afraid to tear stuff apart but for some things such as cyl. head bolts, crank/cam journal and piston rod caps, etc. it may be critical to have the specific information from the manufacturer.
Old 10-24-2009, 02:08 PM   #4 (permalink)
...now ...you're getting into torque specific/required/mandatory stuff there..
...for the other ....German will do..
jetfuel..auf wiedersehen
Old 10-26-2009, 09:27 AM   #5 (permalink)
mendo's Avatar
You will be happy when you do this.
clean up the manifold right where it hits the head. that spot is rough.
I noticed an improvement right away.
Be Careful when you remove the bolts, 2 of mine came out with the studs too. Also, be careful when you re-install it. make all the bolts finger tight, then tighten the bolts on the manifold to the head so that surface sits really nice. then tighten all the supports from there out.
Old 10-26-2009, 01:45 PM   #6 (permalink)
silverbrabus's Avatar
Originally Posted by mendo View Post
clean up the manifold right where it hits the head. that spot is rough. I noticed an improvement right away.
I was wondering if this would be worth the effort. Looks like it's time to get out the Dremel.
Gaskets reusable?
Lug nut / bolt torque partsrme928 smart Wheels & Tires 13 12-17-2010 01:28 PM
New Torque Link SmartTech smart Modifications 2 04-28-2009 10:46 AM
Torque Link mendo smart Modifications 6 04-15-2009 07:00 PM
torque specs Periclaws smart Wheels & Tires 3 03-01-2009 07:17 AM
Exhaust manifold torque? GHammerly smart Modifications 2 10-25-2008 03:12 AM
