Fabric sunshade installation - Smart Car of America Forums : Smart Car Forum
LinkBack (4) Thread Tools Display Modes
Old 03-20-2008, 11:31 PM   4 links from elsewhere to this Post. Click to view. #1 (permalink)
While trying to remove some of the interior trim I made the mistake of removing one side of the sun screen. As you would expect the assembly is under spring tension to assist in re-rolling the fabric. I had not anticipated the fact that the only thing holding it together was the screws holding it to the car. So as soon as one side was down the tensioning thread popped off the spool holding it. It took a couple a couple of beers and some thinking to figure out how to get it put back together and then how to get it back in the car in one piece.
The tensioning thread runs from the spool (1) forward to the front pulley (2) then back to a guide (3) and clips to the spring which sits on a pin (4). If it just fell down from it's mounting after you removed the last screw it won't look like this.
To reassemble:
1: unclip the spring from the pin (4) and remove it from the guide slot (3) and lay it out on the floor ahead of the front pully. Do this for both sides.
2: keeping the shade as straight as possible, wind it around the roller into the fully open position. At this point the tensioning thread will be wound around the spool.
3: pull outward on the socket until it clears the pin on the end of the spool. Pull the winding thread off the spool to the side and put the pin back in the socket. Do this for both sides.
4: take the spring and run the thread through the guide(3) and leave it laying in the slot, don't put it on the pin yet. Do this for both sides.
5: re-tension the shade on the roller & make sure that it is straight. pull the pin from the socket again and run the tensioning thread around the back of the spool from bottom to top. It should be resting on the thick part of the spool. It will want to drop down between the pin and the socket or over the top onto the roller. You may have to go back and adjust this if it moves during the rest of the process. Do this for both sides.
6: make sure the thread runs forward & over the front pulley. It will probably be to one side of the pulley instead of on it. Its easiest to use a #20 torx to remove the pully & center the thread. You may have to repeat this too as you finish adjusting. Do this for both sides. The picture below shows the thread run incorrectly, its off to one side.
7: check that the thread is correct on the rear spool and front pulley then clip the end of the spring over the pin(4). Do this for both sides.
If things have gone correctly the shade should be under slight tension holding it open & it should resemble the first photo. The next problem was how to keep it together. If you pick it up the spool pin will pop out of the socket, the thread will come out & it's back to square one. I tested this.
The solution was to tie a loop of string through each of the rearmost mounting holes. The two loops should not meet if you pull them together. Size it to leave an few inches between them when they are under tension.
Very carefully, with your hands over the socket on each side, turn the shade over so that the underside of the shade is facing up. Pull the two loops toward each other and use a zip tie to tension the assembly enough to hold it together but not hard enough to break anything.
You can now re-install the shade in the car. Support the shade by the roller with one hand and put one of the center screws in on each side but leave them loose. Install the rest of the screws but don't tighten them yet. Cut the string loops & remove them. Snug each of the screws then test the operation of the shade & adjust them before the final tightening.
Or just don't mess with the thing in the first place. That would be my recommendation.
Good luck
Guy
gamsberry is offline   Reply With Quote
The Following 2 Users Say Thank You to gamsberry For This Useful Post:
Brabus007 (12-15-2011), smartelda (08-25-2011)
Old 03-21-2008, 07:52 AM   #2 (permalink)
Lgaruti's Avatar
Guy,
Thanks for the info. Your "just don't mess with the thing" recommendation will be followed to the letter....
Lgaruti is offline   Reply With Quote
Old 03-21-2008, 08:10 AM   #3 (permalink)
Made this a sticky; don't want it to get lost and someone else have the same problem. Thanks for posting - great info.
Old 05-30-2008, 09:28 AM   #4 (permalink)
thinksmart's Avatar
Need some help please. I purchased 3 smarts (2 05' passions and 1 06' passion) for my company from a dealer in Washington. They were brought down from Canada. The inside roof had some kind of fabric coated rubber glued in which i hated. I wanted to experience the view so i tore them off of two of the cars which i really like a lot. Only problem is that they heat up in the sun.
So my question is, does anyone know where i can buy these sundshades to install?
Thanks for the help.
thinksmart is offline   Reply With Quote
Old 06-13-2008, 09:06 PM   #5 (permalink)
Satellite Radio Installation
I had a Satellite radio installed by Best Buy. They took down the roller sunshade and it came apart. They are replacing the sunshade but it's annoying to be without it. Be very careful if you take the sunshade down!
jbnimble is offline   Reply With Quote
Old 06-14-2008, 05:20 AM   #6 (permalink)
I have a 2006 smart and I have the same padded roof that is glued in. I haven't taken mine out yet for that reason. I just saw this magazine called "IMPROVEMENTS" that shows a full Sun Shade for only $45. I figured that it couldn't be the best product out there for only $45,but it might last until more after market products become available for smart.
I am going to get my padded top removed by the company that is doing my wrap. They said that they had some great glue remover and they would do it for me when they had the car. I am going to try to figure out a way to make the padded roof so that I can remove and reapply it if I want.
I am going to try this retractable sun shade. I will let you know.
The SKU # 270888
IMPROVEMENTS is the catalog or go to ImprovementsCatalog.com
Debbie
goldseekur is offline   Reply With Quote
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f25/fabric-sunshade-installation-4626/
Sunshield help - 451 smart fortwo This thread Refback 08-04-2008 05:36 PM
Roof screen problem - smart USA insider This thread Refback 06-30-2008 05:40 PM
Roof screen problem - smart USA insider This thread Refback 06-22-2008 03:57 PM
Roof screen problem - smart USA insider This thread Refback 06-17-2008 11:22 AM
Scangauge Installation bracket jonnysan storage, obsolete threads (locked) 15 09-03-2010 05:47 PM
Installation of 2" Hitch & Bike rack Pictures AlanTravis smart Modifications 53 08-02-2009 01:45 AM
Aftermarket stereo installation tee4 Audio & Video 38 08-16-2008 06:16 PM
Remote Start Installation helidrvr smart General Discussion 5 02-15-2008 03:26 PM
Smart Dash: Fabric/Cloth issues dlent smart General Discussion 3 02-04-2008 03:03 PM
