A vast collection of (almost)
all technical infos (start at post #1)
SCoA MEMBERS ONLY
http://www.smartcarofamerica.com/for...library-17651/
Car won't start after
disconnected battery: re-teach the car
Disconnected battery - won't start!
Certain
fuses are missing in the NA 451 Owners Manual (pg 285). List at:
Missing Fuse Page Redux
DIY
Gear Shifter and Lube (Video @ post #48)
DIY gear shift removal and lube (short video)
How to adjust your
headlights, very easy!!!
http://www.smartcarofamerica.com/for...ent-easy-4088/
How to install a switch to defeat the "on all the time"
heated mirrors
Heated mirror switch DIY
Replace/repair the cabin air
heater/AC electric fan
http://www.smartcarofamerica.com/for...-repair-26967/
How to
Jack Up Your Smart Properly
Jacking points
Disassembling, changing the
key battery:
Key Went Through Washing Machine
Locked out and the car batter'y dead, someone's experience and tips on how to open the door
http://www.smartcarofamerica.com/for...al-hole-36145/
Reset
Maintenance Interval
Reset Maintenance Interval
or
or
Maintenance indicator reset (service wrench)
Online Technical
Manual (by subscription, cheaper than smart's)
http://www.smartcarofamerica.com/for...-manual-37475/
Gas
Miles per Gallon tracking
Gas Miles per Gallon tracking
How to change your
oil in the smart
Semi-official "how to change your oil"
List of oil/filter
http://www.smartcarofamerica.com/for...860-post4.html
Parts, good source for used parts, including full engines
Blown Engine,,,Please Help!
Rear Window Washer's not getting fluid? Check the connection (pic)
Rear (window) washer
Shifter Stuck in Park, here is the get home now fix
Shifter stuck in park - Here's the get me home fix.
Maximize
shifting for optimum MPG/torque...
http://www.smartusa.com/Downloads/Ho...el-Economy.pdf
Fabric
Sunshade Installation
Fabric sunshade installation
My Car Won't Start and the display reads
three bars instead of P
My Car Won't Start! [3 lines thru "P"]
When all else fails, check our in-house Supporting Tuner.
