OK, I'll admit I've considered this before. Although I have a pretty good science background, not so much on the technicalities of automotive engineering. I'm not so swift on alternators / generators either. Although the alternator is always turning, is it always putting out the same current? And, if the answer is no, does it require more energy to turn it when it is cranking? If its normal state is putting out more current than is required by the system, where does that current go?
I already admitted ignorance, so no need to rub that in. Life is learning.
