Old 02-13-2009, 02:27 PM   #1 (permalink)
Drive: 2008 smart passion
Front End Allignment Specs.
Has any one found the specifications for the front end allignment on the 451? I have 27k+ miles on mine and the front tires are worn out.
I have a set of rear wheels to put on the front and I am going to put a set of 4 185/60/R15 on the car.
The allignment shops don't seem to have the specs yet.
Old 02-13-2009, 02:33 PM   #2 (permalink)
JOIN SCOA..YOU'LL BE GLAD
Drive: modified 65 stang conv
...just this time...
for 451.3.. & 451.4.. chassis the specs are:
front
camber (at 0 toe) 0 deg 18' + or - 30'
caster 7 deg 50' + or - 30'
toe 36' + or - 10'
rear (All 450, 451 & 452 chassis)
camber -2 deg 00' + or - 30'
toe 0 deg + or - 18'
front caster and camber can be adjusted slightly by loosening all 4 lower control arm bolts and sliding the whole assembly left/right forward back as needed (holes are enlarged to allow some movement)
Front toe is adjustable.
Rear is not adjustable at all
jetfuel...join SCOA...you'll be glad you did
Old 02-13-2009, 02:52 PM   #3 (permalink)
Jet you are a Gentleman and a Scholar.
Old 02-13-2009, 03:10 PM   #4 (permalink)
eqwalker's Avatar
Drive: 08passion,09Brabus
Okie, I'm right there with you. I have 25k+ on mine and my fronts are worn out on the inside edges. Is that where yours are worn? I was thinking mine must be out of alignment to wear them out at such low mileage.
Old 02-13-2009, 03:49 PM   #5 (permalink)
Yes the inside edges of the fronts, which would suggest excessive negitive camber or excessive toe-out. Seems to be a common problem and made worse by not being able to rotate the tires. The back tires are doing ok.
Old 02-13-2009, 11:18 PM   #6 (permalink)
Karl Roth's Avatar
Sounds to me like a toe problem, camber will most likely not case your problem, over driving the chassis on the other hand will.
UK smart specs jwight The Car Lounge 3 08-10-2008 05:00 PM
Radio 10 Specs ck_az Audio & Video 1 06-01-2008 07:33 PM
451 Specs lhoboy smart fortwo (451 - US vehicle) 15 10-10-2007 07:54 PM
