Originally Posted by jediknight36
This leads me to a question i had posted months ago: Is there anything a person can do who has no choice buy to buy Gasoline with 10% ethanol in it? I use Chevron that has the same amount of Techron in all three of its choices (Texico has merged, so they have it too). Sure, it will keep the engine clean, but is there anything I can add to cut back on the MPG robbing ethanol?
The 10% that we are stuck with now is a mandate of the Clean Air Act whether is actually necessary to attain local EPA air quality levels or not (they vary by location). Unfortunately, the Act will require a much greater percentages of ethanol in the future just to replace gasoline, unless it is rescinded.
Actually, ethanol has a natural higher octane rating than gasoline, so theoretically, compression ratios can be increased to compensate. There is always a trade-off though. Because corn ethanol has a lot of nitrogen compounds in it (from fertilizer), the increased cylinder temperatures associated with high compression will increase NOx levels. We would be better off with water/alcohol-injected, lean-burn technology when we need some additional performance.
