Old 07-12-2008, 11:48 PM   #1 (permalink)
Fuel Gauge flashing???
Twice the fuel gauge in my wifes smart has gone bezerk after superfilling, flashing all the bars on and off. The first time it kept flashing it until it got below half a tank, then resolved itself just as we were about to take it in to get looked at.
This time it's flashing for a while, then goes back to normal except for random fuel levels, and then starts flashing again.
Has anyone else seen this or know what the cause may be?
Most of the time we superfill and have no issues.
Pete
petep99 is offline   Reply With Quote
Old 07-13-2008, 03:01 AM   #2 (permalink)
Mod./Adm.
Drive: w/s/r '08 passion
The owner's manual specifies clearly that one shouldn't "superfill". Stop at the first click! Otherwise you'll get some conflicting results, like an engine malfunction, and possibly the one you just posted...
Old 07-13-2008, 05:47 AM   #3 (permalink)
Please define "Superfilling"
Pete
Please define the word "superfilling".
rollingtones is offline   Reply With Quote
Old 07-13-2008, 06:14 AM   #4 (permalink)
Mod./Adm.
Well, in my post above, I understood that "superfilling" was in fact toping it off...
Am I, as usual, wrong?
Old 07-13-2008, 07:35 AM   #5 (permalink)
7,000 miles of smiles
mdfortwoguy's Avatar
Drive: '02 VUE, '08 Passion Coupe
Oy... surprising your CEL isn't on from the superfilling.
Old 07-13-2008, 01:45 PM   #6 (permalink)
Well thank god for that. Would you like to share what your acronym means?
The question was not if I should or should not. The question was has anyone else seen this symptom as a result.
Superfilling is a bit more than just topping off. There are quite a few discussions about it elsewhere.
Old 07-13-2008, 02:32 PM   #7 (permalink)
And it WILL damage your smart. Reading the manual is good. The manual is your friend...
Old 07-13-2008, 03:14 PM   #8 (permalink)
Suze's Avatar
Drive: 08 Passion Pink zippy
CEL - check engine light - also known as engine malfunction indicator. And I'm surprised you haven't had it, too. It happens when the tank is over filled or if the gas cap isn't tightened properly or if you look at it sideways.
What are the advantages of "seperfilling"?
Old 07-14-2008, 02:45 PM   #9 (permalink)
pcvinsel's Avatar
Drive: '08 Smart ForTwo Coupe
Hmmm... I can't find any other references to "superfilling" on this forum, and Google doesn't seem to help. Can you give a bit more detail of what "superfilling" is, or a link to the other discussions about it?
Peter
pcvinsel is offline   Reply With Quote
Old 07-14-2008, 07:42 PM   #10 (permalink)
smart happens here!
SmartCard's Avatar
Drive: Red/Bk Cabrio, '04 JCW MCS
superfilling entails dipping your gas tank in liquid nitrogen, proceeding with a normal fill, closing the top real tight, and then allowing the system to warm up to ambient temperature...which then pressurizes the gas tank to 45 psi.
flash, flashing, fuel, gauge, superfill
Fuel Gauge problem smarish Smart Car Operation and Maintenance 3 06-20-2008 05:37 AM
Took the gas gauge to 0.0 unicycle Smart Car General Discussion 69 06-17-2008 11:11 AM
Fuel Gauge Stuck On Full redbluff Smart Car Operation and Maintenance 11 06-16-2008 02:53 PM
flashing center brake light donnyonee Smart Car Modifications 11 05-31-2008 02:44 PM
fuel gauge reading t-bone Smart Car Operation and Maintenance 10 02-11-2008 04:52 PM
