Fumoto oil drain valve - Smart Car of America Forums : Smart Car Forum
Old 06-09-2008, 02:37 PM   #1 (permalink)
has anyone investigated the possibility of using a fumoto oil drain valve instead of the OEM bolt and crush washer? i've used the fumoto application successfully with my lifted jeep and it makes draining oil behind the underbody skidplate pretty effective, i have the fumoto with the nipple end so i can attach a hose to reach beyond the skidplate, this keeps oil from draining all over the skidplate top side.
Old 06-09-2008, 02:54 PM   #2 (permalink)
The smart bolt is more than a bolt; the oil drain plug has a mesh filter attached to it, reportedly for the oil pickup. Changing to another bolt or drain loses that filter.
Old 06-09-2008, 03:09 PM   #3 (permalink)
the oil pickup is integral to the drain plug? that's weird.
Old 06-15-2008, 02:54 AM   #4 (permalink)
Lucy! You've got some esplaining to do!
I've not changed my oil yet, so I haven't seen the drain plug yet. But I don't understand why a filter would be attached to the plug and how this would help the pickup. Shouldn't the filter be attached to the end of the pickup?
Old 06-15-2008, 03:42 AM   #5 (permalink)
It appears like the screen on the drain plug is a debris trap so that anything roaming around with the free oil (and not in the filter) is concentrated in the vicinity of the plug and will come out with the screen of flush out when the plug is pulled.
Old 06-15-2008, 05:01 AM   #6 (permalink)
Most oil pumps have a pickup screen that isn't odd in itself. Clever or should I say smart, is the ability to easily clean this at each oil service it insurure full oil flow. A more conventional design requires removal of the oil pan "sump" and oil pump pickup, hours of labor. Seems to make removing the plug once a year or so no big deal anymore. An other challange with the drain petcock systems is that they can form a dam for particulates that have fallen out of suspension in the oil and settled to the bottom of the sump.
Old 06-15-2008, 05:16 AM   #7 (permalink)
There is a good depiction here of where the screen fits into the oiling system, and how it works: www.smart.com
Old 06-15-2008, 07:49 AM   #8 (permalink)
i don't know about the screen - never had a problem with the valve-style design on my jeep which is 170K miles on it and is run quite hard off-road. if it doesn't work in this application, so be it. was just a suggestion.
Old 08-03-2008, 08:25 AM   #9 (permalink)
Do all you 451 owners know that the 450s with the Mercedes Benz engine don't even have oil drain plugs?
Old 08-03-2008, 08:52 AM   #10 (permalink)
Smart Enuf's Avatar
Fumoto doesn't list smart as a compatible application:
Engin Oil Drain Valve - Fumoto Engineering
Of course, this list was last updated in April 2005, so who knows?
Last edited by Smart Enuf; 08-03-2008 at 08:53 AM. Reason: included update information
that damn purge valve sensuellenhot smart General Discussion 19 06-03-2008 07:35 PM
Success with Dump Valve on smart 450 rgaus Modifications and Repairs 28 04-07-2008 04:48 PM
Does the 451's have a drain plug? Smartfor2guy smart Operation and Maintenance 2 02-01-2008 04:49 PM
Oil pan w/drain hole and magnetic drain plug jwight Original (450) smart fortwo 11 12-18-2007 10:27 AM
