Gas Gauge STILL has problems - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 02-08-2009, 09:53 AM   #11 (permalink)
Padawan's Avatar
After a dealer reflash and a few tanks of fuel that were still showing 7/8, mine seems to have finally worked itself out. I follow the exact method quoted here, and then wait another 30 seconds or so before switching the car on, and have had my gauge read full each time now. I've also started using MMO (Marvel Mystery Oil) just as I've done with my other cars, and perhaps this has helped lubricate the sending unit a bit. As an aside, I do seem to notice slightly better fuel economy after beginning the MMO usage, but I haven't tracked it consistently enough to be certain.
Originally Posted by Duckhunter View Post
I do slow fuel(1st click) untill shut off, let fuel settle for about 15-30 seconds then slow fuel untill clicks off again. Should take very little fuel. I have not had a problem getting last bar since. Happened only once on mine. Try different pumps? Last resort could be a mal adjusted sending unit.
Padawan is online now   Reply With Quote
Old 02-08-2009, 10:11 AM   #12 (permalink)
Has anybody noticed the sticker on the gas filler lid which says "Do not top off"?
There's actually a reason for this. You WILL soak the carbon canister in the vent and fixing it will be expensive.
Old 02-08-2009, 12:06 PM   #13 (permalink)
There is a difference between just verifying that the tank is full by letting the fuel settle and one attemp at filling slowly again til pump clicks off again and doing this multiple times and overfilling tank. On my truck I have been able to put 3-4 extra gallons in by forcing it in. I will never try this in the smart. I have yet to have one issue with the way that I verify I have indeed filled the tank.
Duckhunter is online now   Reply With Quote
Old 02-08-2009, 12:37 PM   #14 (permalink)
And does your truck have a sticker on the fuel lid saying "Do not top off"?
Didn't think so...
Old 02-08-2009, 12:49 PM   #15 (permalink)
NeWave's Avatar
Mine's sometimes 7, sometimes 8. Quiktrip's slow notch seems to fill it perfectly every time, cause when I attempt one last squeeze in, it just clicks. Shows all 8 bars. Other places like Shell and Phillips have a faster "slow" notch, and I get a bit in on the extra squeeze in and then end up with 7. As long as it gives me mostly accurate, then I'm fine. I don't run my tanks down... usually fill at 1/4 tank, so it doesn't matter much to me.
Old 02-08-2009, 01:06 PM   #16 (permalink)
Didn't think so...
Yes it does tell you "DO NOT TOP OFF" in the owners manual
Old 02-08-2009, 01:11 PM   #17 (permalink)
After it clicks off on mine it will also pump almost none in untill it clicks off the second time. Like I said in my previous post the second click just verifies full tank. Every once in a while the pump may click off early if another pump causes a pressure fluctuation.
Old 02-08-2009, 04:01 PM   #18 (permalink)
Padawan's Avatar
The procedure I quoted from Duckhunter comes straight from smart itself as their recommend fill method. It just isn't included in our US owners manuals (which seem to lack a bunch of other info that the European manuals include). Following the procedure won't damage anything.
Old 02-08-2009, 04:02 PM   #19 (permalink)
tbone28's Avatar
That's interesting. Did your dealer tell you this, or did you see it in the European owner's manual?
Old 02-08-2009, 04:16 PM   #20 (permalink)
Padawan's Avatar
Fueling
Gas Gauge Malfunction daleharrison smart Operation and Maintenance 57 05-20-2010 01:49 PM
Gas Gauge Again Butch smart Operation and Maintenance 12 01-07-2009 03:45 PM
Gas Gauge Alan From New York smart General Discussion 27 12-27-2008 09:19 PM
Took the gas gauge to 0.0 unicycle smart General Discussion 69 06-17-2008 12:11 PM
