Gas Mileage - Effect of Air Conditioning? - Smart Car of America Forums : Smart Car Forum
Old 05-14-2009, 10:39 AM   #1 (permalink)
Now that summer is almost here in the Houston area, running the air conditioner is NOT optional. Any ninny from the North who thinks we can simply roll down our windows needs to try it down here when at 7:00 AM the temperature is already 80 and the humidity 95%.
It is difficult to measure how much mileage drops due to AC, but I would like to see some other guesses in addition to my own, so please post what you thing you are seeing on your Smart. With Mr. Bean, he seems to be getting 2.5 to 3.5 mpg less. I am consistently getting 36 - 38 where before my range was roughly 38 - 42. This is in the Houston suburbs, so no hills, mix of 35 - 55 roads, and about 25% doing 65 on freeways. Definitely quite a bit of sitting in traffic waiting for lights.
And your Smartie's results??
seadave is offline   Reply With Quote
Old 05-14-2009, 10:51 AM   #2 (permalink)
amoore007's Avatar
I ran air all of last summer on my 110 mile commute via I59.
I say it is 4mpg lower based on 4,000 rpm or 79 mph.
It might be less if I would slow down.
I am turning 30,000 miles on the smart next week with only one service problem.
It has been a blessing during these economic times. AL
amoore007 is offline   Reply With Quote
Old 05-14-2009, 11:48 AM   #3 (permalink)
In the first three tanks when I didn't know the "full up" venting kicked in the A/C, I got 3-4 mpg less than the following tanks when I didn't have the A/C engaged automatically in cool weather. While I saw a "step function" in mpg, the break-in of the car may have affected the results slightly. I tend to run my tank down to around 0.1g before fillup so the results I get for a tank are pretty accurate.
I have at least 20 miles below 0.0g but a recent check of how much fuel under 0.1g by weight suggests that might be about my limit!
Old 05-14-2009, 12:02 PM   #4 (permalink)
John,
You may want to peruse this:Pro-Tech Auto Center-Fuel Pumps
Old 05-14-2009, 12:10 PM   #5 (permalink)
OK - what the heck is "full up" venting and A/C engaging automatically??
Old 05-14-2009, 12:22 PM   #6 (permalink)
Your vent dial has 12 settings with three points of 100% of the air one direction: at 4 o'clock the air is 100% out of the console vents, at 8 o'clock the air is 100% out of the floor vents, at 12 o'clock the air is 100% out of the windshield vents. It's the 12 o'clock position I call "full up" venting because SO many people talk about the 12 o'clock position being the "defrost" setting which doesn't describe the reason I want to blow air there.
When the vent is turned to all-windshield at the 12 o'clock position, the A/C is automatically engaged even though the A/C button has not been pressed nor is there indication the A/C is on from the LED on the button.
So. If your vent dial is set to 12 o'clock or "full up" your A/C is on unless the outside temperature is approaching freezing.
Old 05-14-2009, 12:53 PM   #7 (permalink)
CWCjr's Avatar
Originally Posted by chieftmc View Post
John,
Do you or anyone else know if the Smart Car's fuel pump is in the gas tank?
CWCjr is offline   Reply With Quote
Old 05-14-2009, 12:56 PM   #8 (permalink)
Yes, it is. The smart fuel pump shuts itself off before it runs dry and overheats or pumps air into the supply line.
Old 05-14-2009, 01:13 PM   #9 (permalink)
In the smart guide to Maximizing Fuel Economy
http://static.ning.com/smarturbanist...%20Economy.pdf
It clearly stated if you run the AC in stop and go traffic it will increase consumption by up to 30%, But at steady Highway speeds the A/C barely increases fuel consumption.
And - Close your windows when driving on the highway. Open windows increase the aerodynamic load thereby making your engine work harder.
So smarts answer is open windows in stop and go trafic with a/c off, and close them at highway speeds with A/C on.
So avoid stop and go traffic in the hot weather.
Old 05-14-2009, 01:26 PM   #10 (permalink)
OK, so it's cool enough in Wisconsin so you can turn the ac off and open the windows in stop and go traffic. In Houston such an action would typically leave you in a puddle of sweat in about five minutes. The car would also have to be fitted with some sort of bilge pump in the floorboard to remove the accumulation of sweat before it starts sloshing around. If you had a passenger they would likely file suit for unusual and cruel punishment.
The folks at Smart as well as my friends in cooler climes will have to read my lips - RUNNING WITHOUT A/C IN HOUSTON SUMMERS IS NOT AN OPTION. ...But considering the amount of fuel consumed, I'll keep 'er running, thank you very much. Also interesting they say up to 30%. So far the replies on this post have pegged it more like 10-15%.
Thanks for the good comments!
keeping cool in houston,
seadave
increased volume and speed effect theguywiththelongestname smart Operation and Maintenance 7 04-04-2009 01:29 PM
Blizzard Warning in effect Neonspinnazz Illinois Chapter 6 01-13-2009 05:54 AM
Air Conditioning and gas mileage? Docthrock smart Operation and Maintenance 23 05-04-2008 07:44 PM
smart 451 with ground effect mods JetJazz smart Gallery 8 12-24-2007 12:39 PM
Air Conditioning choppermike smart General Discussion 3 10-02-2007 06:58 AM
