Gas Miles per Gallon tracking - Page 16 - Smart Car of America Forums : Smart Car Forum
Old 04-26-2008, 12:12 PM   #151 (permalink)
I'm approaching the middle of my service interval, so I thought I'd report. Mileage keeps getting a little better. Car is 3 months old with approx 4400 miles. Commute loop is 32 miles each way with 1/3 suburban, 1/3 highway, and 1/3 mountain/hill driving. Last fill-up gave me 48.4 mpg. Using automatic mode with the only exception being that I shift to neutral at stops. No special brand of gas (I switch between Costco, Shell, and occasionally Chevron), but I do use premium.
The car is better than I expected in this respect and I can still highly recommend it as a daily commuter.
prm1177 is offline   Reply With Quote
Old 04-26-2008, 08:20 PM   #152 (permalink)
dancote's Avatar
Mid-grade Report
My last fill-up was with mid-grade (89 octane). Mileage on this tank was 43 MPG. We had been averaging 42-43 MPG so no appreciable change.
Car has 2500 miles. Driven exclusively in "auto" mode. Usually with driver and passenger. Not much stop & go. About half this tank was freeway miles @ 65-75 MPH. Most of the other half was in a suburban setting with lots of hills.
dancote is offline   Reply With Quote
Old 04-26-2008, 08:45 PM   #153 (permalink)
Smartical's Avatar
The manual states you need 91 octane. Have people found it necessary or can 89 octane w/ Ethanol work ok?
Smartical is offline   Reply With Quote
Old 04-26-2008, 08:58 PM   #154 (permalink)
Not sure about the ethanol, I've run mine on 87, 89, 91, 93 and cannot tell the difference.
Old 04-26-2008, 09:03 PM   #155 (permalink)
Smartical's Avatar
Thanks!
Cool. There is about a $.25/gal diff now between 89 and 91 here.
Old 04-26-2008, 09:14 PM   #156 (permalink)
Short trips worse than long trips
Originally Posted by jthomas119 View Post
You (and the others that responded with similar comments) are right. Just as another experiment, I drove our Prius on the same 2 mile trip. When cold, it got 23 mpg. This is a bit less than my smart which got 26 mpg. And the Prius had the advantage of the engine turning off when I stopped at a light for a minute or so. When warmed up, the Prius got 52 mpg for this same 2 mile tirip which was better than the smart but to be expected from a hybrid.
The bottom line is that if you have a little short trip to make, either ride your bike or combine your trip with other needed trips. I will have to admit that the fact that my little smart is so much fun to drive has caused me to use much more gas than I need to. While waiting for my smart, we were a one car family and for 6 months, I survived by only riding my bike during the weekdays. I need to go back to bike riding, it is healthier for me and the environment even if it is not as much fun.
John
John, that makes sense. I read advice somewhere, I think in a Popular Mechanics or Mother Earth News hypermiling article, that if you have to cross town on a round trip of errands, go to your farthest destination first. That'll warm up the engine to its optimum temp, so most of the driving is made while it's warm. Once I get my ScanGauge installed I'll have to test that theory.
On the Prius 2 mile trip, the battery charge is another factor... how much battery was used vs engine? It's possible the first trip had low enough battery that the engine was used to charge, and the second trip used the fully charged battery most of the time. In any case, your 4 mile round trip averaged about 36mpg, still low enough for a hybrid to confirm the short-trip syndrome you observed.
Old 04-27-2008, 12:08 AM   #157 (permalink)
Ok. Working mode...mileage report.
Sea level, Hwy 101, Central Oregon Coast. Mostly two lane, some passing spaces. Lots of s l o w motorhoming tourists. Frequent long hills, curvy river roads. Small towns, few lights. About a hundred smiles to the mile.
Chevron (highest octane here is 91)
99% auto, sometimes shifting because I get nervous when the tach is below 2000.
Picked her up on 02/29/08, and she came with a full belly, 28 miles on odo.
Date..........Trip.......Gals............MPG...... ..........Miles.....$/Gal.....$ Fill
03/05/08 ..286......7.287 ..........39.24 ..............286 .....3.599....26.23
03/11/08 ..248.1 ...6.531 .........37.98 ..............534 .....3.659....23.90
03/13/08 ..266.9 ...6.791 .........39.30 ..............801 .....3.649....24.78
03/20/08 ..259.5 ...7.346 .........35.32 ............1061 .....3.679....27.03
03/24/08 ..284.0....7.185 .........39.52 ............1345 .....3.619....26.00
04/02/08 ..250.7 ...6.790 .........36.92 ............1596 .....3.679....24.98
04/10/08 ..272.6 ...7.037 .........38.73 ............1868 .....3.819....26.87
04/11/08 ..297.7 ...7.296 .........40.80 ............2166 .....3.699....26.99
04/18/08 ..241.2 ...6.635 .........37.00 ............2412 .....3.739....24.81
04/23/08 ..232.1 ...5.726 .........40.53 ............2644 .....3.799....21.75
04/25/08 ..224.6 ...5.643 .........39.80 ............2869 .....3.859....21.78
(If the spacing doesn't post right, I'll have a booboo face)
So, I can look and see that when I go up to Tillamook, down to Waldport, more mountains, worse mileage (36-38) and more local, fewer hills, better.
So, in DOLLARS per MILE: <drumroll>
Cost per gal: 3.86
MPG: 39.8
MP$ 10.31 MILES PER DOLLAR
( http://www.unfocusedbrain.com/projec...es_per_dollar/ and
http://forums.vwvortex.com/zerothrea...int&id=3675662 )
I'm not the lease bit disappointed - except in the obscene profits of gouging oil companies.
............Lonely Gas Station.............Bwaaaaaaaaa
CruzinSusan is offline   Reply With Quote
Old 04-27-2008, 12:09 AM   #158 (permalink)
booboo face
So I added dashes, got stars...
In my next life,m I want to be a nerd.
Third try...better.
Old 04-27-2008, 06:10 AM   #159 (permalink)
wahi's Avatar
Nice log, susie. Mine's at 3000, I have all the receipts, and will recompile my smart report using your template soon.
wahi is online now   Reply With Quote
Old 04-27-2008, 03:58 PM   #160 (permalink)
Originally Posted by SnakeFarm View Post
BTW, How IS that ac?
Tell me it's COLD. (I want ice hanging off my beard here.)
We have noticed that the ac is not all that great. I would have chosen a white car, but my wife thought the blue was cuter. We'll see how cute it is in August.
The heat works fine, though. We had it on today for the April cold front.
jpmcdonough is offline   Reply With Quote
Why is it needed to change the oil within the 1st 100 miles vs 3K 2micro4u smart Operation and Maintenance 144 11-15-2009 09:16 AM
Cargo tracking your smart spdickey smart General Discussion 362 06-14-2009 08:13 AM
Smart car runs 340,000 miles in 5 years Rogue Smart smart News & Rumors 6 11-22-2008 10:55 PM
IF Gas Prices reach $4 a gallon or higher... BobDiaz smart General Discussion 125 06-21-2008 05:00 PM
Cargo tracking-ARC? micmou smart General Discussion 0 01-16-2008 07:48 AM
