Gas Miles per Gallon tracking - Page 5 - Smart Car of America Forums : Smart Car Forum
Old 02-27-2008, 01:34 AM   #41 (permalink)
Originally Posted by Dave777 View Post
Today I took a long drive, including in an area where it is nearly flat for a few miles. (Hard to find any area like that around here.) The ScanGauge is hooked up and running, but I can't trust the MPG numbers yet as I haven't been able to calibrate it with a fillup. So, these numbers are best used as comparative, not absolute. The ScanGauge has an averaging mode that can be reset at any speed. Give it a few minutes at a steady speed and level surface, and the numbers are quite accurate. I ran for a few minutes at each of the following speeds, resetting for each one, and came up with these numbers:
40 MPH**-52 MPG
50 MPH**-51 MPG
60 MPH**-45 MPG
70 MPH**-38 MPG
Great info Dave, thanks!
Dave, or anyone with a scangauge or other mpg reader:
Could you do another steady comparative run, this time, at 45 mph?
I'm wondering if there may be a sweet spot in there somewhere, maybe at 45 mph, that jumps the mileage up to 53 - 57 mpg or so.
Also, while some factors may be obvious, since you have the scangauge, it would be helpful if you could list (even the obvious ones) the factors/driving style that gets the greatest mpg, and the worse mpg.
for example, 1) you might do a run, of coasting, for a minute, or so, slightly downhill, (and another on flat) and note the speed at the beginning of the coast (say 55 mph), and the speed at the end of the coast (say 35 mph), and the mpg over the coast span. ... another from 50 mph to 30 mph. another from 45 to 25mph. or other similar runs.
2) the worst, i guess is at a stop light. 0 mpg.
3) maybe do a run, where you coast up to the stop light, say, beginning at 35 mph, and ending at 10 mph when the light changes, and note the mpg over the span.
4) maybe a run, noting the average mpg from 0 to 50 mph in a steady acceleration, a) taking about 15 seconds. b) a second run, 0 to 50 mph, in 20 seconds. c) a third run, 0 to 50 seconds, in 25 seconds.
5) and/or repeat 4 above, but 0 to 60 mph, instead of 0 to 50 mph.
6) basically, any other techniques, that can help one who doesn't have a scangauge yet, ... that seems to show up on your scangauge as giving great mpg, or less bad mpg.
... another run might be, trying different fuels. On the same stretch, same fuel, mark the mpg on several runs. Then, on the next tank, change the octane, to whatever you may be interested in trying (that you feel wont hurt your engine), and re do the mpg ave test with the different fuel, to see if fuel makes a difference.
... another run test might be, to try that 0 to 50 acceleration test, once using the manual shifting, and again, using the automatic mode. to see if one is different.
... or, try a tank of gas, with all auto mode, then another tank of gas, all manual mode.
or any other scangauge, or similar mpg device, test run you feel would be interesting, to boost mpg. Thanks.
mr_Cash is offline   Reply With Quote
Old 02-27-2008, 12:06 PM   #42 (permalink)
kwagar's Avatar
4th fill-up.......227.6 miles...5.8 gals = 39.5 MPG
Total so far....969.9 miles...25.37 gals = 38.2 MPG
kwagar is offline   Reply With Quote
Old 02-27-2008, 06:49 PM   #43 (permalink)
Dave777's Avatar
Did my second tank fillup today, and first where I knew how it had been filled previously. Squeezed in as much as I could both times. (Yes, I know this isn't a good idea to do regularly) This last tank I did lots of freeway driving at 60 MPH and some State highways at around 50 MPH.
340 miles, 6.417 gallons.
52.98 MPG! 4.44 L/100KM
Better than I thought I'd get.
I don't anticipate getting that all the time, but it looks like mid 40s should be regularly attainable. I'm a very conservative driver when trying to get good mileage, and the ScanGauge is great feedback during the process.
Old 02-27-2008, 06:53 PM   #44 (permalink)
Dave777's Avatar
mr Cash,
It sounds like you have a very strong interest in a variety of mileage techniques, and likely greater than my interest. I simply try to drive normally, just not very aggressively and rarely over the posted limits.
You should definitely invest in a ScanGauge.
Old 02-27-2008, 10:54 PM   #45 (permalink)
I assume with the radio playing and AC blowing...cool
Old 02-28-2008, 01:23 AM   #46 (permalink)
mr Cash,
Well, how about just a test run, comparable to your earlier runs, at 45 mph.
and if you have a chance, also at 55 mph.
Thanks.
Old 02-28-2008, 01:29 AM   #47 (permalink)
Dave777's Avatar
Thanks.
If the opportunity comes up, I'll try. The area where we live has no level roads. The location I did this was nearly two hours away.
Maybe someone in Texas or Florida can give it a try.
Old 02-28-2008, 04:16 PM   #48 (permalink)
dancote's Avatar
Fill-up #4 = 40.85 MPG (U.S.). Slightly less than my last fill but I attribute that to my increasingly heavy right foot.
dancote is offline   Reply With Quote
Old 03-02-2008, 09:55 AM   #49 (permalink)
1st Month Mileage 35.36 MPG
I've been in my new "smart" since 1/31/08 and I've driven 1,388 miles and used 39.25 gallons of premium gas. That works out to 35.36 miles per gallon.
peterb38 is offline   Reply With Quote
Old 03-02-2008, 10:27 AM   #50 (permalink)
Hello to all posting here: there is a site http://fueleconomy.gov where you can record calculate and share your milage with any interested parties there are dang few cars listed far less than post here Thanks
the average there is 36.4
Why is it needed to change the oil within the 1st 100 miles vs 3K 2micro4u smart Operation and Maintenance 144 11-15-2009 09:16 AM
Cargo tracking your smart spdickey smart General Discussion 362 06-14-2009 08:13 AM
Smart car runs 340,000 miles in 5 years Rogue Smart smart News & Rumors 6 11-22-2008 10:55 PM
IF Gas Prices reach $4 a gallon or higher... BobDiaz smart General Discussion 125 06-21-2008 05:00 PM
Cargo tracking-ARC? micmou smart General Discussion 0 01-16-2008 07:48 AM
