Gear Knob Button STUCK!! - Page 3 - Smart Car of America Forums : Smart Car Forum
Old 04-15-2008, 02:58 PM   2 links from elsewhere to this Post. Click to view. #21 (permalink)
a2jack's Avatar
No Dealer Fix.
There is no fix the dealer can do for a shifter that stucks in Park.
It's a simple procedure to release the shifter so that the car can be driven home or to the dealer. (I will post release procedure later today)
Don't try put it in park again. The whole assy must be replaced.
A2 Jack.
a2jack is online now   Reply With Quote
Old 04-15-2008, 07:19 PM   #22 (permalink)
a2jack's Avatar
Here's the get me home fix.
Small HOZ strip of tape marks place to put fingers to pull/up console cover.
Same spot on other side. Aprox !0 + 2 clock positions.
Long VERTICAL tape points to position where you will see the YELLOW lever under the left bottom edge of cover.
1. Slip fingers slightly between bottom edge of the cover and the carpet. Pull up and back ,and snap the cover loose, but do pull up over an inch or so. Be gentle. Prop up front of cover about an inch.
2. On the ground, looking in under the cover from the drivers side, you can see a yellow lever just inside the cover. WITH THE KEY ON , Lift this yellow lever while wiggling and pulling the shifter down, out of park. (Wife used a pen to lift the lever).
3, Do not try to use Park again until the whole shifter box has been replaced.
4, Feed back is appreciated so that we can refine this fix.
A2Jack
Old 04-15-2008, 10:10 PM   #23 (permalink)
Dave777's Avatar
Good job. That should be in the owner's manual, but since it isn't I'm going to print it out and put it in mine.
Thanks for posting that!
Old 04-15-2008, 11:37 PM   #24 (permalink)
curtis's Avatar
the car i test drove had the same issue, kind of worries me...
Old 04-16-2008, 06:26 AM   #25 (permalink)
SloPok's Avatar
A2Jack
Can you drill a hole into the cover so you can insert a pen (as your wife did) to move the lever without having to remove the cover?
SloPok is offline   Reply With Quote
Old 04-16-2008, 07:44 AM   #26 (permalink)
a2jack's Avatar
SloPok. Great Idea, as I believe this may be an ongoing problem.
I have been told there will be new boxes for the 2009 cars. I sure hope they can be retrofitted to our "Old" 2008s.
The box looks like a game controller with a joy stick sticking out the top. It's a true sealed "Black Box" and the service people do not know what's inside.
A2Jack
Old 04-16-2008, 10:05 AM   #27 (permalink)
Godfather's Avatar
Anyone know if this is common to all production to date, or a specific run of cars?
Old 04-16-2008, 10:18 AM   #28 (permalink)
robotbill's Avatar
It seems to be hit or miss. Tough to tell since not everyone posts here. My guys here say that not all cars sold at Smartcenter Bedford have had this problem. This is mentioned at some other websites including Canadian. I find it interesting that Evilution has not weighed in on this. Has this not been seen in the European markets?
robotbill is offline   Reply With Quote
Old 04-16-2008, 11:46 AM   #29 (permalink)
PassionforPassionCT's Avatar
Probably for this new fangled North American Shifter. Remember the Euro road show cars, had a different (better, IMO) shifter.
PassionforPassionCT is offline   Reply With Quote
Old 04-16-2008, 12:00 PM   #30 (permalink)
Admin/Mod.
US and non-US gearshifts
US
non-US softip
non-US softouch
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f25/gear-knob-button-stuck-4454/
Club smart Car > Get Home Fix For You Stuck shifter. This thread Refback 07-02-2008 09:28 AM
Get Home Fix For You Stuck shifter. - Club smart Car This thread Refback 05-17-2008 05:00 AM
Key is stuck in Ignition Bob_Parr smart Operation and Maintenance 48 05-08-2008 02:55 PM
My roofs locked and stuck down mybabyjackblack New Members Area 1 02-09-2008 12:29 PM
Stuck Inside of Mobile... Smartman smart General Discussion 1 01-10-2008 03:59 AM
Gear Shift Delay MicroNut smart General Discussion 12 11-11-2007 08:37 PM
Fifth gear review of new smart tipo158 smart Videos 1 09-12-2007 03:48 PM
