Going down... (transmission) - Smart Car of America Forums : Smart Car Forum
Old 02-10-2008, 11:06 AM   #1 (permalink)
gusfraga's Avatar
My house is located in a very steep hill. Every time that I drive down the hill I set the car to neutral to avoid high RPMs
I wonder if this will affect the clutch/engine/car is any way?
Old 02-10-2008, 11:24 AM   #2 (permalink)
24-42's Avatar
In first gear, would the car still accelerate? If so, let the engine do the braking until the rpm is as high as you want to limit it, then assist with the foot brake.
Donald LaFavor
Old 02-10-2008, 03:18 PM   #3 (permalink)
BeSmart's Avatar
Break in period
Donald LaFavor
Hi Gusfraga and Donald, I'm not sure, but I think smart recommends a break-in period in engine breaking. Not sure what it is. The owner's manual should have some comment on this.
BeSmart is offline   Reply With Quote
Old 02-10-2008, 04:04 PM   #4 (permalink)
Senior Smartie
jonnysan's Avatar
Break in rpm limits
For first 500 miles, engine rpms should not exceed 4000 rpm or 2/3rds of max rpm. IF you don't have a tach, you'll have to use some judgement by the sound of the engine. There is no break in period for engine breaking as such....don't understand your wording there....the limiting factor is RPM whether engine braking or accelerating.
John
Old 02-10-2008, 04:04 PM   #5 (permalink)
GHammerly's Avatar
I would be good for the engine braking period if you used it to help slow down your car, negative cylinder pressure is good for your compression rings brake in period.
Just keep the RPM to a reasonable level.
Old 02-10-2008, 09:48 PM   #6 (permalink)
Not Selling on Ebay
gusfraga, putting any car in neutral and coasting down a hill will not do anything to engine or clutch, however, you will be very hard on the brakes because the engine is not helping with the braking.
Transmission oil Bob T Original (450) smart fortwo 19 03-09-2011 07:27 AM
Not sure I can get used to the transmission magnetman smart General Discussion 49 09-03-2008 03:23 PM
transmission charles kitch New Members Area 5 05-28-2008 04:17 PM
Another Transmission Thread - Sorry shack01 smart General Discussion 18 03-10-2008 12:11 PM
A question about the transmission JanetMermaid smart General Discussion 2 11-17-2007 04:50 PM
