Head lamp Clip- lo beam - Smart Car of America Forums : Smart Car Forum
Old 11-02-2009, 07:16 AM   #1 (permalink)
While changing burned out lamp, I have inadvertently lost the retaing clamp / spring. Does not appear to be a dealer item?
Any suggestions?
blusmart is offline   Reply With Quote
Old 11-02-2009, 10:37 AM   #2 (permalink)
Any suggestions?
At this time the only way to get the spring is with with the whole head lamp assembly. And yes I think thats a little crazy.
I would try a salvage yard. Also try calling your local smart dealer as if they are like me anytime we get a vehicle in that was involved in an accident and have to replace parts we have learned to save the bits that are hard to get.
smartSEATTLE is offline   Reply With Quote
Old 11-02-2009, 11:47 AM   #3 (permalink)
fastturb's Avatar
not sure exactly what it looks like but how about a paper clip? since you still have one on the other headlamp, you could (CAREFULLY) remove that one and bend the paper clip to match.
Old 11-02-2009, 01:38 PM   #4 (permalink)
Worth a shot, but I think a paperclip is too soft a metal to hold the bulb. ?
I could be wrong, I was ONCE, thought I was wrong, but I wasn't
Old 11-09-2009, 03:06 PM   #5 (permalink)
You might try going to a motorcycle shop. They often use those type of bulbs and probably would have some extra clips available. Lots of 'Off Road' folks might also have some.
Enjoy - Life's too short not to!
spunoff is offline   Reply With Quote
Old 11-09-2009, 03:10 PM   #6 (permalink)
Drive: Pulse
All else fails, PM me. I can get you a smart oem clip, pretty much immediately.
Bil in British Columbia, Canada.
Old 11-10-2009, 12:57 PM   #7 (permalink)
head light clip
sunnyokanagan
I would be appreciative!
What do I need to do?
Old 11-10-2009, 12:57 PM   #8 (permalink)
I do not seem to be able to do a PM (private message)
Old 11-10-2009, 01:03 PM   #9 (permalink)
Just click on sunny and click on "send private message"
Old 11-11-2009, 09:18 AM   #10 (permalink)
pabille's Avatar
I feel for you. I've almost lost that flimsy clip, myself, when replacing one of the bulbs. I did a Google image search for H7 sping clip and there might be other vehicles that use the same or similar clip. I know the clip is easy to remove. It stays on with tension. After unclipping the bulb, squeezing the two arms together removes the pivoting end from the two pinholes it pivots in. You might pull out the other side and see if you can match it up with a clip from another car. Just be careful.
Good luck.
pabille is offline   Reply With Quote
Left low beam headlight burned out vwW12 smart Operation and Maintenance 45 07-16-2011 07:38 PM
New HID High Beam Set Now in Stock! SmartMadness Vendor Marketplace 21 02-13-2010 09:27 AM
smart car clip art dichrodave Off-Topic Cafe 9 05-08-2009 04:55 PM
Push in clip P/N jwight smart Operation and Maintenance 8 10-03-2008 08:00 AM
News Clip Old smart smart News & Rumors 5 09-18-2007 07:49 PM
