Old 08-05-2008, 11:21 PM   #1 (permalink)
Paul A's Avatar
Drive: Blue Passion
Headlights flickering
Has anyone had this problem.
My headlights on low beam flinker slightly while driving at any speed. If I have them on high beam it will do the same but you can hear a clicking sound coming from the LH side of the dash.
My Dealer so far, has checked for a loose ground. Changed out the turn switch. which didn't help. Now my light in the radio will go off sometimes when I use my turn signal. It will come back on if I turn the radio off and on. And yesterday my headlights went off then on when I used my right signal. My Dealer has ordered a new sam unit, which hasn't come in yet. But not sure if that will fix it.
Paul A is offline   Reply With Quote
Old 08-06-2008, 04:06 AM   #2 (permalink)
Amethyste's Avatar
Drive: Crystal White Smart Cabrio
Check your battery cable connections!! Mine were doing that too and that was all it was. Are you sure your dealer did check that correctly?
Amethyste is offline   Reply With Quote
Old 08-06-2008, 11:10 PM   #3 (permalink)
Paul A's Avatar
Drive: Blue Passion
I don't know if he checked that or not, But I can do that myself so I'll check it out. If it fixes it I'll let you know.
Thanks
Old 08-07-2008, 03:20 AM   #4 (permalink)
Drive: 97 Civic HX and 99 Corolla
I had a car come in the other day with similar symptoms and it was the battery ground cable (it was loose). Your symptoms do sound more serious... the car I was working on just had flickering lights (all around the car) when the engine was running, but they looked normal when the engine was off.
SmarTek-TNG is offline   Reply With Quote
Old 08-10-2008, 11:13 PM   #5 (permalink)
Paul A's Avatar
Drive: Blue Passion
I checked my ground cable, and I could move all the wires and turn the ground screw with my fingers. Tighted it up, and so far so good.
Thanks for the reponse.
Old 09-07-2008, 03:07 PM   #6 (permalink)
Macaw's Avatar
Drive: '08 Pure black/silver
7,000 miles and just now driving in the dark and noticed the flickering lights. Battery cable was ok but one of the ground nuts on the chassis by the battery was loosey-goosey....
Old 09-07-2008, 03:50 PM   #7 (permalink)
Fredvon4's Avatar
I think it real interesting that Automotive technicians for the last 10~20 years rarely seem to be trained to find the simple things FIRST
One o One for any electrical troubleshooting when I was training young aircraft repairmen; was to verify all power and ground connections FIRST... then ensure good connectivity on every electrical connector in the circuit before even suspecting a bad black box..................
"ordered a SAM unit"... there was a goodly expense for the dealership....
Please all you ASE certified Master Tecnicians out there ...do not read this as a Bash on ALL technicians...
But if you can accept that there is a lack of good training out there, perhaps you could take the time to mentor some of the younger guys and gals to not overlook the simple stuff
I hate to say how many alternators I have seen replaced on a car or truck with battery terminals damned near falling for for all the corrosion
Old 09-07-2008, 04:05 PM   #8 (permalink)
Old smart's Avatar
Drive: fortwo premium coupé
I can say that during my own PDI (POST delivery inspection) I found my battery ground strap barely tight - on both ends!
Old 09-07-2008, 05:10 PM   #9 (permalink)
bigcritter's Avatar
Replaced a "good" alternator on a Chevy once, then had to take it back off after finding the ground cable on the battery (at the engine/chassis) was bad! click....click......click.......
Old 09-07-2008, 05:37 PM   #10 (permalink)
Cruising n Coasting's Avatar
Drive: Black Beauty x3
I haven't done this yet after 1800 miles, maybe now is a good time.
painted headlights babybenz Interior & Exterior 22 09-23-2009 11:53 PM
DIY: Painting your headlights cubefx Smart Car Modifications 73 04-02-2009 09:07 AM
Broken Headlights! Please Help! matweekly Smart Car Operation and Maintenance 6 06-08-2008 09:26 AM
Blacked out headlights SMART Interior & Exterior 12 04-12-2008 03:32 PM
Headlights SloPok smart fortwo (451 - US vehicle) 7 03-01-2008 01:10 PM
