Heated mirror switch DIY - Smart Car of America Forums : Smart Car Forum
Old 09-20-2008, 02:18 PM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
MECPofPA's Avatar
Heated Mirror Fix Step-by-Step Part 1 of 2
To take grzzlycanuck 's solution, which I think is k.i.s.s. I'll provide how to make this happen.
Things you will need to perform this FIX.
1) Soldering Gun & Solder (and the skills to use it)
2) Electrical Tape
3) Heat-Shrink Tubing
4) 3 Female Tongue Connectors
5) 1 Illuminated 12vdc switch (I used a Radioshack 275-0018)
6) 1 18" Black automotive hookup wire (I used 18 gauge)
7) 2 18" color-of-your-choice automotive hookup wires (same guage)
8) approx. 1/2" drillbit
First release the S.A.M. (the one with the fuses) from its holder (do NOT remove any wires!) so it looks like this as viewed from the left.........
Where I have label SWITCHED POWER are locations R1-R4.
The WHITE fuse holders are what we are interested in.
One of them has TWO BLACK wires with BLUE STRIPES.
This is the one we will be concentrating on. These are the heated mirrors and there is one wire for the left an one for the right.
Proceed to remove the fuse from only this fuse-holder and begin to pull the TOP of the WHITE fuse holder away from the S.A.M. like this.....
When released it will look like this.......
Now CUT the wires approx. 3-4" from the end like this.......
Now solder and heat-shrink one of your selected-colored-wires to the pair that runs off to the heated mirrors like the following......
Now take the OTHER-colored-wire and do the same for the pair coming FROM the fuse-holder like this......(also insulate when done)......
Now go ahead and connect the BLACK wire to a suitable ground and terminate EACH wire with the Female Connectors like this.......
I STRONGLY suggest you label at least one of the colored-wires i.e. the wire coming from the fuse holder as POWER.
The illluminated 12vdc switch I chose from Radioshack looks like this.....
On the back it has 3 male terminals labeled, POWER, LOAD and, no kidding, EARTH.
SEE PART 2 of 2
Edited
MECPofPA is offline   Reply With Quote
Old 09-20-2008, 02:22 PM   #2 (permalink)
MECPofPA's Avatar
Heated Mirror Fix Step-by-Step Part 2 of 2
I found a quite suitable, (there's that word again) location for the switch in the left cubbyhole. I drilled an almost 1/2" hole approx. 2" DOWN from the TOP and 1" from the LEFT. This clears molding and everything in the back.
Now route the 3 wires from the back thru the hole here.....
By the way, if you need to use the switch's retaining ring, put it over the wires in the back before putting wires thru panel.
I was able to make the hole snug enough so I was able to screw the switch into the panel.
Connect the BLACK wire to EARTH, POWER wire from fuse-holder to POWER and the remaining other color wire going to the heated-mirrors to LOAD. Using electrical tape, insulate each terminal well.
Now stuff it into the cubblehole and you're DONE!
Edited as per OP's request
Old 09-20-2008, 03:15 PM   #3 (permalink)
Admin/Mod.
MECPofPA, I took the liberty of copying those two posts into an independent thread in order to make a sticky out of it in the Maintenance FAQ. Thank you!
Old 09-20-2008, 05:04 PM   #4 (permalink)
Really nice fix and relatively simple as well - thanks!
Old 09-20-2008, 05:25 PM   #5 (permalink)
DFWehman's Avatar
MECPofPA Thanks for doing this, excellent photos and explaination! I put a 12v socket on the right side of the cubby (another Radio Shack part!) and the thread that outlined that mod said to avoid the left side. Sounde like you confirmed there were no technical issues with that side. Clean install, loos great! Now I know my mirrors won't melt or burst into flames ... ;)
Old 09-20-2008, 05:57 PM   #6 (permalink)
WilyB's Avatar
Awesome DIY thread! Thanks MECP.
Old 09-20-2008, 08:01 PM   #7 (permalink)
MECPofPA's Avatar
JPAUL - Take the updated pages as some important stuff was left out i.e. the first paragraph and spelling has been corrected.
Old 09-20-2008, 08:27 PM   #8 (permalink)
Admin/Mod.
Replaced posts with the edited ones you originally posted and corrected. BTW you can edit these too. Only the listing of FAQs/DIY is locked.
Old 09-21-2008, 05:36 AM   #9 (permalink)
smartHHO's Avatar
You would think that instead of making them feel for the moisture or whatever they are looking for, that they would make them like the rear defrost. Why have power to them all the time. You get failed sensor and wham, they always on. Or always off. Smart, if you reading this, you should give this guy some cudos and make this standard on the 2010, since the 09 is already in production. Sheesh.
Old 09-21-2008, 06:44 AM   #10 (permalink)
smart happens here!
SmartCard's Avatar
Nice job! Certainly will do this if any issues develop with having the mirrors on all the time.
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f25/heated-mirror-switch-diy-14102/
Exterior mirror heaters ON 100% of the time. Yours too? - smart USA insider This thread Refback 10-23-2008 02:48 PM
Exterior mirror heaters ON 100% of the time. Yours too? - smart USA insider This thread Refback 10-14-2008 11:29 PM
Exterior mirror heaters ON 100% of the time. Yours too? - smart USA insider This thread Refback 10-01-2008 01:11 PM
Cabrio Top switch - problem?? phillysmart smart Operation and Maintenance 13 04-11-2010 03:24 PM
Mystery Switch The Silver Pellet smart fortwo (451 - US vehicle) 27 03-05-2009 12:14 PM
Tailgate switch change jwight smart Operation and Maintenance 0 07-07-2008 01:03 PM
Simple bulb switch PassionforPassionCT Interior & Exterior 3 06-29-2008 10:02 PM
Airbag switch? abseventeen smart Modifications 7 03-18-2008 12:28 PM
