Heated Mirror Fix Step-by-Step Part 2 of 2
I found a quite suitable, (there's that word again) location for the switch in the left cubbyhole. I drilled an almost 1/2" hole approx. 2" DOWN from the TOP and 1" from the LEFT. This clears molding and everything in the back.
Now route the 3 wires from the back thru the hole here.....
By the way, if you need to use the switch's retaining ring, put it over the wires in the back before putting wires thru panel.
I was able to make the hole snug enough so I was able to screw the switch into the panel.
Connect the BLACK wire to EARTH, POWER wire from fuse-holder to POWER and the remaining other color wire going to the heated-mirrors to LOAD. Using electrical tape, insulate each terminal well.
Now stuff it into the cubblehole and you're DONE!
