Heated mirrors stay on all the time! - Page 9 - Smart Car of America Forums : Smart Car Forum
Old 09-06-2008, 05:37 PM   #81 (permalink)
Fredvon4's Avatar
No Chiefmc that is exactly what many of we Super Duty truck owners did... The greif comes with owners hacking up a factory harnes, (warranty isse with ignorant service departments) and a good quality and location for the switch for each morror.
Motorheads like me that are also Master Electricians have no problem with the modification but it is a pain and serious concern for the typical owner operator who does not want the potential re-sale or warranty grief
Old 09-06-2008, 06:13 PM   #82 (permalink)
DFWehman's Avatar
Fredvon, I'm capable of implementing once you post the DIY thread! Was looking at the switch bank mod in one of the other threads. Granted those are momentary closure, but coupled with a latching relay... could be interesting!
Old 09-06-2008, 06:23 PM   #83 (permalink)
Dave777's Avatar
I'm not a master electrician, so won't be hacking into the wires . I'll wait and see if smart has a fix via software update. It's possible.
Old 09-06-2008, 06:23 PM   #84 (permalink)
Fredvon4's Avatar
Not trying to be a Wise ass here...does this car have a warning tell tale when OAT is at or near freezing?
I am out at Seattle this week and away from my trusty (POS) owners manual. Many cars these days provide OAT on the drivers info center... usually they have a snow flake or Icy Icon when the OAT approaches 32~34F....
One would think logically this would trigger the exterior mirror heat circuit... and if present would be the most elegant Hack
Wonder how adept Kane is a sniffing out the OAT sense signal in the SAM unit
I hate having all sorts of Ideas but zero time to research and experiment... This is the very longest I have owned a new car absolutely Bone Stock...
Old 09-06-2008, 06:26 PM   #85 (permalink)
Dave777's Avatar
Fred, the owners manual is right there, on the first page, on the left.
Old 09-06-2008, 06:28 PM   #86 (permalink)
DFWehman's Avatar
Isn't there air temp in the instrument cluster, or are you talking about something else?
Old 09-06-2008, 06:57 PM   #87 (permalink)
SmartDigger's Avatar
Originally Posted by p1nball View Post
Scan Gauge in the Volt setting , last night from work. It stayed at 14.0-14.1 with all lights on, even the high beams. It never has been that high with the mirrors on. It showed 13.7 13.1. It even had an effect on the a/c blower speed. Has to effect the fuel economy some what!!!
I speak the truth. p1nball
If it is drawing that much current... Then it should be on its own circuit. Put switch in the blank center switch bank.
Old 09-06-2008, 07:12 PM   #88 (permalink)
Why not hook it into the circuit that controls the heated rear window? Seem logical that the two would be wanted at the same time.......
Old 09-06-2008, 07:22 PM   #89 (permalink)
Old SGM's Avatar
Originally Posted by chieftmc View Post
I'm no engineer, but seems like you could just take the "ground" side, snip the wire, but a switch inline and be done! Am I "over simplifying" this?
I like that idea, the switch could be mounted on the door inside panel, that would be an easy fix. We would just need to find a presentable switch.
Old 09-06-2008, 07:28 PM   #90 (permalink)
Fredvon4's Avatar
Dave trip seven... SCOA Front page has a owners manual PDF? Must be blind, I do not see it
And IF memory (even with CRS) serves, you posted the DYI on the brake light pulsar mod... Thus you certainly have the skills to pop the inside door mirror cover off...find the heat circuit wire... clip, solder, heat shrink wires and insert a on/off rocker switch... on the hot or ground side...and cut/fab the appropriate sized hole/slot in the inner cover for the switch and test...
The simplicity is there for us to hack....
I seriously doubt we will ever see a software fix...note we are many months into USA deliveries and 09s are immentnet... DRL are possible to be functional with a SAM unit software fix and they fail to even acknowledge that our market could benefit from the OPTION ...weird because as several other markets have DRLs implemented and optional by button sequence manipulation
Part of this thought (no software fix) is predicated on the knowledge that the OAT sense is not run through the SAM but directly applied to the Instrument cluster so no soft ware can detect the 32F~34F OAT and activate the SAM heater relay circuit
heated mirror problem, heated mirrors stay on
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f25/heated-mirrors-stay-all-time-13347/
Outside mirror heat always ON 451 - Club smart Car This thread Refback 09-03-2008 06:12 PM
Outside mirror heat always ON 451 - Club smart Car This thread Refback 09-03-2008 05:31 PM
Outside mirror heat always ON 451 - Club smart Car This thread Refback 09-03-2008 05:26 PM
License plate won't stay in mnext02 smart General Discussion 8 09-01-2010 07:36 AM
Reservation time to Configuration time to Delivery time t-bone smart News & Rumors 289 03-12-2009 10:54 AM
Make your radio stay off when starting the car. brian r Interior & Exterior 20 10-13-2008 09:49 PM
Mirrors Vibrating Carl242 smart Operation and Maintenance 12 06-26-2008 08:20 AM
Long Time Listener, First Time Caller! TomO750 New Members Area 6 06-20-2008 12:41 PM
