Hill Start Assist - Smart Car of America Forums : Smart Car Forum
Old 02-12-2008, 03:09 PM   #1 (permalink)
SmartyPants25's Avatar
Hill Start Assist
So I haven't noticed any hill start assist in my car. I was parked on a hill the other day, facing downhill and I was behind another car, I put it in reverse and it immediately started rolling forward, I had to use the hand brake in order to back up without rolling forward. This hill was not a very steep one either. Anyone else have this experience? This seemed to also happen last night, I wasn't even on a hill, I flipped a U on a small residential street and couldn't quite make it fully, put it in reverse and rolled forward to the curb!
SmartyPants25 is offline   Reply With Quote
Old 02-12-2008, 03:11 PM   #2 (permalink)
could be wrong, but i believe the hill assist is designed to work when going uphill, not downhill. i've never had a car that has downhill assist.
Old 02-12-2008, 03:24 PM   #3 (permalink)
GHammerly's Avatar
I guess you wanted to go up hill but in reverse, I don't know if it has hill start assist in reverse, I know it has this feature when going fwd. in first gear up a grade.
Some one out there with a smart try and find out.
Old 02-12-2008, 03:32 PM   #4 (permalink)
Javichanche's Avatar
I own a new Smart 451 and the hill assist is designed to work uphill and down hill.
Javichanche is offline   Reply With Quote
Old 02-12-2008, 03:44 PM   #5 (permalink)
MarkB's Avatar
I just assumed it was for going uphill. Brakes do a pretty good job for downhills in my experience.
MarkB is offline   Reply With Quote
Old 02-12-2008, 04:29 PM   #6 (permalink)
well, according to the Smart manual I have, it does not. (nor does it on the Lexus version of hill assist).
verbatim: "On uphill grades the hill start assist system maintains the pressure in the brake system for approximately one second after you have released the brake pedal. Therefore, you can start off smoothly without the vehicle moving immediately after releasing the brake pedal."
makes no reference to downhill grades.
Old 02-12-2008, 06:44 PM   #7 (permalink)
SmartAzz's Avatar
Yeah, I've never heard of hill assist working when facing downhill. On the test drive I tried it out uphill on a bit of a grade and it worked nicely.
Old 02-13-2008, 04:40 AM   #8 (permalink)
If the brakes are held set (for 0.7 second) at start-up, what difference does it make to the car whether the car if facing up hill or down hill? Brakes are brakes; they work in both directions.
Because rolling backwards on a down hill start is a non-problem, the manual probably ignored the situation in print.
Old 02-13-2008, 05:14 AM   #9 (permalink)
BandSofC's Avatar
With an automatic clutch - how do you know the computer isn't just slipping the clutch to hold you? For that matter - if there's no clutch pedal, why do you need hill-start assist? I have 2 feet.
BandSofC is offline   Reply With Quote
Old 02-13-2008, 06:20 AM   #10 (permalink)
It is the brakes that hold for 0.7 second, not the transmission.
Remote start rwj53 smart Operation and Maintenance 18 12-19-2010 09:48 AM
Noise when you first start the car eqwalker smart fortwo (451 - US vehicle) 10 02-21-2008 05:02 PM
jump start??? maxtraxduffy smart Operation and Maintenance 19 01-27-2008 10:26 AM
smart center Cherry Hill - NJ (Mercedes-Benz of Cherry Hill) SMART smart center Dealerships 0 01-06-2008 03:27 PM
Old Thread just new start point. Billc smart Reservations 6 12-02-2007 05:16 PM
