Old 05-03-2008, 03:53 PM   #1 (permalink)
Hot engine
I've had my Passion for 1 week and drive it around the neighborhood and notice that it doesn't take much for the engine, luggage area and back panels to get really hot. Should I be concerned or is this "normal"?
stilamama is offline   Reply With Quote
Old 05-03-2008, 04:06 PM   #2 (permalink)
Dave777's Avatar
Drive: 2008 smart Passion
Not sure what you mean by "really hot."
A 5 minute drive around the neighborhood is barely enough time to get the coolant warm, let alone the entire luggage area.
Yes, you'll feel a bit of warmth coming from the floor of the engine compartment, but I've never felt it was "hot." It's pretty well insulated.
Old 05-03-2008, 04:50 PM   #3 (permalink)
wahi's Avatar
Drive: G.C, Subaru, Pure
MY scangauge shows the water temp in my smart to be at between 188-198 F during normal operations. It tends to be at 193 F most of the time. That's my smart's 'normal' temp.
wahi is online now   Reply With Quote
Old 05-03-2008, 05:18 PM   #4 (permalink)
Dave777's Avatar
Are you talking about inside the car, or outside?
Old 05-03-2008, 05:49 PM   #5 (permalink)
Not hot
4 hours of solid driving didn't melt a Twix bar stored in my cargo area. Out back, that vent was putting out some serious heat, as designed.
Make sure your engine compartment cover is on right. If not, I imagine it could vent hot air (not exhaust) into your cargo area. You should see and feel no gaps.
That's serious insulation and venting; the cargo area cover's only a few inches from the manifold. I don't think it gets past 90 degrees on the top side. Any other car, the hood is too hot to touch.
Old 05-03-2008, 05:55 PM   #6 (permalink)
Drive: 2008 Cabrio
scangauge temp
Were can you read that info on your scangauge? Thanks........
Old 05-03-2008, 06:04 PM   #7 (permalink)
wahi's Avatar
Use the Scangauge II in its 'GAUGE" function and you should see four displays. As you press the button, you will see the gauges change names alphabetically. To show water temp, you should stop at FWT (that's Fahrenheit; Water Temperature).
I have IGN, RPM, FWT and MPH readings on display most of the time.
Old 05-03-2008, 06:09 PM   #8 (permalink)
Drive: 2008 Cabrio
Thanks
Thanks for your help on the scangauge, I just got mine a week a go.
Engine heating the car? jediknight36 Smart Car General Discussion 37 08-12-2008 01:07 PM
Engine Revs GliderDude Smart Car General Discussion 6 02-09-2008 07:09 PM
80k miles out of the engine?? maxtraxduffy Smart Car Operation and Maintenance 3 01-27-2008 08:20 AM
NVH and engine sound MikeJCW Smart Car General Discussion 8 01-16-2008 11:47 AM
Mitsu Engine. a2jack Smart Car Gallery 11 11-16-2007 02:12 PM
