Key Fob - Smart Car of America Forums : Smart Car Forum
Old 08-13-2008, 07:42 PM   #1 (permalink)
happy smarting
GetSmrt28277's Avatar
Key Fob
Has anyone had problems with their key fob? 4 months old and stopped working..not dropped, near water or anything else I can think of. I know how to change the battery (thanks to Evilution) and have not changed it yet.
Thank goodness I was at home where the spare was at.
Any issues out there on this yet?
GetSmrt28277 is offline   Reply With Quote
Old 08-13-2008, 07:46 PM   #2 (permalink)
Admin/Mod.
One member had the key in his pocket and a colleague told him that his smart kept beeping: something was actually pressing on the key/fob buttons at every step, triggering the car (through walls, though not far) to re-lock each and every time. Obviously, that would have drained the battery quickly...
Since that post, I make sure that the fob isn't in a position to be pressed-on accidently.
In "normal" use, a key should last 1-2 years before a battery change is needed.
Old 08-13-2008, 07:54 PM   #3 (permalink)
Rmichael1's Avatar
sure enough
Yep, my key does the same thing I found when I was washing it with key in pocket I kept setting it off. Reposition the key and continue. Hope that's all the problem you had. My New Beetle key was about $180 to replace.
Rmichael1 is offline   Reply With Quote
Old 08-13-2008, 08:14 PM   #4 (permalink)
minibmw's Avatar
Key Fob Replacement & Other issues
Well 8k miles (1st one in MA) and no problems until about a week ago. I left my key in the ignition for a week (in my garage) while I was away and when I came back, the battery was dead. There were no accessories or lights on... it seems the key drew enough over the week to kill the battery.
Also I lost my second key fob and just ordered a replacement for $163! $46 for the metal part of the key and $107 for the "radio" fob part + taxes!
I ordered the key when I brought it in for a sticky shifter - difficulty getting it in and out of Park. That has been the first problem of any kind I have had... not even a rattle or squeak!
minibmw is offline   Reply With Quote
Old 08-14-2008, 04:28 PM   #5 (permalink)
happy smarting
thanks for the replies. So far, it lives on my counter at the front door and is only in my pocktbook while I am at work. I'll know if it is the battery this weekend.
It the key part of the warranty?
Old 08-14-2008, 04:38 PM   #6 (permalink)
Admin/Mod.
No reason it shouldn't! Unless you damage the key (i.e. run over) or loose it. Then, replacement is a $300+ proposition, it requires new programming "live" from Smartville/Europôle.
