Key Fob Will Not De-activate Immobilizer - Smart Car of America Forums : Smart Car Forum
Old 07-20-2008, 01:04 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Drive: Pulse
It seems I'm having trouble with the computer that controls the door locks and the immobilizer. Pressing the "unlock", "lock" or window "unlock" buttons on the key only casuses "ticking sounds" to come from the dashboard. None of the buttons activate the locks in any way - the unlock button does not disengage the door lock, the lock button does not engage the door lock and the back window button does not disengage the back window lock. I put a new battery in the key with no luck.
However, the main lock and unlock buttons do activate the lights that flash when you lock press to unlock the doors - just no action from the locks.
Unfortunately, the immobilizer does not disengage either and I could not start my car and had to call roadside assistance and have it towed to the dealer.
It's a 2006 fortwo pulse.
Any thoughts?
Eugene
Dukester is offline   Reply With Quote
Old 07-20-2008, 02:48 PM   #2 (permalink)
you lost sync with your car. Ive read up on other forums and here about if you push the button on the key fob a certain number of times without being close enough for your car to receive your signal the key rolls code much like the rolling codes of garage door openers and now your car and key need to be hooked up to a Mercedes star diagnostics system to be resynced via a key code set that comes from your vin number.. you have a 06 maybe its a g/k and if so call eddie and he will charge you $500 dollars to have you send him your ecu and ignition and keys to resync your whole car back to new.
taken from another forum
The key works like this:
The transmitter's controller chip has a memory location that holds the current so many bit code. When you push a button on your key fob, it sends that so many bit bit code along with a function code that tells the car what you want to do (lock the doors, unlock the doors, open the trunk, etc.).
The receiver's controller chip also has a memory location that holds the current so many bit code. If the receiver gets the so many bit code it expects, then it performs the requested function. If not, it does nothing.
Both the transmitter and the receiver use the same pseudo-random number generator. When the transmitter sends a so many bit code, it uses the pseudo-random number generator to pick a new code, which it stores in memory. On the other end, when the receiver receives a valid code, it uses the same pseudo-random number generator to pick a new one. In this way, the transmitter and the receiver are synchronized. The receiver only opens the door if it receives the code it expects.
If you are a mile away from your car and accidentally push the button on the transmitter, the transmitter and receiver are no longer synchronized.
The receiver solves this problem by accepting any of the next so many possible valid codes in the pseudo-random number sequence. This way, you (or your three-year-old child) could "accidentally" push a button on the transmitter up to so many times times and it would be okay -- the receiver would still accept the transmission and perform the requested function. However, if you accidentally push the button so many time + 1, the receiver will totally ignore your transmitter. It won't work anymore.
It's called a rolling code system.
both keys need to re-synced to the car if one goes out
i have a buddy with a 08 and he lost sync just going for a walk in a store with a i phone in his pocket... it took smart sj many try's to learn how to perform the process
2Smarties is offline   Reply With Quote
Old 07-20-2008, 03:01 PM   #3 (permalink)
Any thoughts?
Eugene
have you used this key and remote before? if not, then you may have been given the wrong key and remote. someone on another post had been given the wrong extra set of keys and didn't realize it until a few weeks later.
Old 07-20-2008, 04:35 PM   #4 (permalink)
Drive: Pulse
2Smarties - Thanks - It makes sense. I guess there's such a thing as a bit too smart. I will make sure the dealer gets both keys so they can straighten the whole thing out - I sure hope they pick up the tab on this.
Jeepster55 - this was my regular set of keys - thanks for the heads up.
Eugene
Old 07-20-2008, 04:50 PM   #5 (permalink)
...didn't you get TWO keys from your dealer?
...did you try your spare key?
Old 07-20-2008, 06:45 PM   #6 (permalink)
Drive: Pulse
I was at the ATM when it happened and the other key was at home - unfortunately, smartmove's advice was, we're sending a tow truck within 30 mins - if only they had offered similar advice, I might have taken a cab home and retrived the key - someone else has suggested this and by the sound of it, if it works, it might re-sync everything - I'll keep my fingers crossed and give it a shot in the morning before the towing company takes my pulse 140 kms away to the dealer.
Thanks longestname!
LinkBack to this Thread: http://www.smartcarofamerica.com/forums/f25/key-fob-will-not-de-activate-immobilizer-11462/
mercedes key fob resync - online discussion summary | BoardReader This thread Refback 09-29-2008 10:48 AM
Unlock your Immobilizer, Start your engines 24-42 California Chapter 0 03-21-2008 12:35 AM
Immobilizer standard? New owner . . . OneThinkingGuy smart General Discussion 4 03-01-2008 10:55 PM
