Key Problems - Smart Car of America Forums : Smart Car Forum
Old 05-15-2008, 09:33 PM   #1 (permalink)
SeaDoc's Avatar
Key Problems
Anyone have problem with key where the buttons fall off - which then prevent you from activating door lock/unlock without using a toothpick or other object... Clearly, a defective manufacturing process - contacted dealer - haven't heard back yet...
SeaDoc is offline   Reply With Quote
Old 05-15-2008, 09:36 PM   #2 (permalink)
Not so far; now I've got something else to worry about!
Old 06-16-2008, 08:24 AM   #3 (permalink)
Smart Enuf's Avatar
My lock button is on the verge of falling off. It seems the rubber membrane connecting the button to the rest of the key fob is a bit thin and prone to breakage from repeated use. It should be reparable with an adhesive that works on rubber (assuming it hasn't already fallen off and gotten lost).
Old 06-16-2008, 08:38 AM   #4 (permalink)
mike-in-sa's Avatar
Mine did the same thing about a month before, my key hangs from my belt and the lock button got knocked off. The dealer didn't have a clue how to fix it short of ordering new keys. I found that a BB fits the spot perfect. On top of the BB I put some foam I tore off the koozie holding my beer. I wrapped the key with narrow strips of black vinyl (pvc tape would work too) And now it works as good as before.
Old 06-16-2008, 03:09 PM   #5 (permalink)
Happened to me, got it replaced by the dealer. If this does happen to you, bring both keys to the dealer because if not they will deactivate the one you don't bring.
letsgoskatepool is offline   Reply With Quote
Old 06-16-2008, 03:38 PM   #6 (permalink)
I used some superglue on mine... the LOCK button seems to project a bit higher than the rest.
ckigar is offline   Reply With Quote
broken, button, key, problems
Any problems with your smart? smartielove smart General Discussion 32 05-18-2008 10:22 PM
problems/price belkin666 smart General Discussion 27 03-29-2008 08:36 PM
Any problems getting insurance????? puzzlejunkie smart Delivery 38 03-26-2008 09:32 AM
Had mine one day and have two problems (tailgate, CEL) smarty42 smart Operation and Maintenance 11 02-13-2008 07:59 AM
