Key Went Through Washing Machine - Smart Car Forums
post #1 of 25 (permalink) Old 06-01-2011, 05:33 AM Thread Starter
Well, after two years and 3 months of having the Smart and its fancy electronic key fob, I finally did the "ooops" of leaving it in the pocket of a pair of my pants when I washed them. I've had other cars with remote entry before, just usually on a fob attached to the key like a key chain, not as PART of the actual key. All the other cars I currently have are standard key locks only, no remote entry, so I had TRIED to be careful with the Smart's key, just in case I forgot. And since I'm the one that does the laundry in the house, I don't have anyone but me to blame for not checking the pockets first.
So I went out to the car after JUST pulling the key from the wet pants (pre-dryer, I at least didn't screw up THAT badly), and the car unlocked and locked using the buttons. So I thought I dodged a bullet. This was as I was leaving for work, so I didn't bring my spare key since the main one looked to be functioning fine.
Put in my 8hrs and was walking out the door to go home. Hit the Unlock button on the key, it honked once. Not beeped like the alarm, honked (and blinked the parking lights). I tried the door, it wasn't unlocked. So I hit the button again, still just the single honk. So I tried the Lock button, the car went into Panic mode, honking its horn over and over and over again, with the blinking parking lights. This usually wouldn't be so bad, except I have upgraded my horn, so there is now a LOUD airhorn sounding in the parking lot. Got that to stop, but it still wasn't unlocking. So I removed the keyhole cover (carefully so as to not break the stem), inserted the key and unlocked the door. It has been a while since I read the owners manual, so I forgot that if you open the door using this method the alarm will sound. It did. But at least it was just the siren and not the horn again. I paused for a moment, trying to figure out how to disarm the alarm since the key's buttons were not working. I thought maybe starting the car will work. It did thankfully, as I had already been the cause of too many loud noises in the parking lot.
I drove home and tried locking the car with the key's button. No joy. So I went inside, grabbed the spare and hit the Lock button on it, worked as it should (hadn't been washed. :P). At which point I went back inside and popped open the washed key to see how bad it looked. Didn't snap any pics, but about 9hrs after being removed from the washer, it was still VERY wet inside. I cleaned and dried everything on the backside of the main board and around the battery off as best as I could without access to any alcohol for the electronics as I would have liked, then went out to try the key on the car. Again, no joy. So I went back inside, popped the key open again and took a closer look at the prongs/posts holding the board to the button panel. It looked like you could possibly squeeze the three-headed prongs together to allow the board to slip over them, but I wasn't really sure. I tried it, but wasn't able to get it to budge that way. Then I decided to try just prying up the board away from the button panel, thinking maybe the prongs don't have THAT good of a grip on it. They did not, the board came up and away cleanly. More water/residue on that side of the board which I cleaned off. I put it all back together and figured that I would let it dry out for another 16hrs and try it on the car again.
Lock and Unlock so far are working. I haven't tried the hatch release yet nor the Panic, but will check those in the morning. Hopefully this is it and the electronic board in this key is a bit more resilient than the one in my old Mk III Jetta.
Edit: I want to put some pics on here, but my camera is in the mail coming back from being repaired. I'll update the thread tomorrow with how the rest of the functions are on the key and then put some step-by-step pics in showing the process of opening the key and dealing with the internals so that if anyone in the future needs to do this they'll have a better understanding.
uberpanzer is offline
The Following 5 Users Say Thank You to uberpanzer For This Useful Post:
deepblueQ (06-01-2011), HGB (01-20-2012), kennyrayandersen (06-01-2011), larryw4csc (01-20-2012), louis bolieu (06-01-2011)
post #2 of 25 (permalink) Old 06-01-2011, 05:51 AM
Ex Admin/mod.
Quoted: 25 Post(s)
Would patience pay? I mean after drying what's feasible with a paper towel, keep the fob open to let it dry naturally for few hours. Maybe with the initial help of a hairdryer on its cold setting? No heat, of course...
Just wondering for the next one that has this happen.
JPaul is offline
post #3 of 25 (permalink) Old 06-01-2011, 06:22 AM Thread Starter
Patience did pay off in the end (at least so far, fingers crossed). I had THOUGHT that it was toast before pulling the circuit board away from the button panel, but then found even more water and such between those two surfaces. Dried and cleaned that area out with the towel, reassembled and let it all dry for many hours. And that did seem to work.
Basically hadn't thought about a hairdryer since I was able to get to all the internal parts, once I separated the board from the buttons that is. Had I not been able to do that, I may have resorted to a dryer.
post #4 of 25 (permalink) Old 06-01-2011, 07:57 AM
ManchVegas's Avatar
Quoted: 15 Post(s)
You can also do the cell phone trick of then covering the fob in a bowl of uncooked, dry white rice. The rice will draw the moisture out of the fob.
This trick has been used to rescue cell phones that have been dropped in water or got wet.
ManchVegas is offline
post #5 of 25 (permalink) Old 06-01-2011, 08:08 AM
parnami's Avatar
I've washed my key twice so far without problem. Phew! I was under the impression that the seals on the keys kept water from making it's way inside. Instead, after hearing your experience, I guess I was just lucky.
parnami is offline
post #6 of 25 (permalink) Old 06-01-2011, 08:25 AM
Quoted: 126 Post(s)
yeah, it's kind of surprising -- I washed a memory stick and it had IMPORTANT data on it. I did use a hair dryer but tried not to get it too hot, worked like a charm. Thanks for sharing -- that could come in pretty handy.
kennyrayandersen is offline
post #7 of 25 (permalink) Old 06-01-2011, 08:29 AM
orngandblack's Avatar
Quoted: 74 Post(s)
you could try some wd-40 too. When I dropped my cell in the cats water dish I tried the rice trick but it didn't work. All my buttons when pressed did something they were not suppose to do, I thought the phone was beyond repair. I decided to spray some wd-40 all around inside, around the battery and in every nick and cranny I could find and guess what, it worked. The phone still works today.
orngandblack is offline
post #8 of 25 (permalink) Old 06-01-2011, 08:54 AM
Smart Enuf's Avatar
Originally Posted by ManchVegas View Post
You can also do the cell phone trick of then covering the fob in a bowl of white rice. The rice will draw the moisture out of the fob.
Hopefully, you don't accidentally toss that rice into the rice cooker. That might affect the taste.
Smart Enuf is offline
post #9 of 25 (permalink) Old 06-01-2011, 08:57 AM
Smart Enuf's Avatar
Yup, that's what WD-40 was invented to do (WD 40 = water displacement perfected on the 40th try).
post #10 of 25 (permalink) Old 06-01-2011, 11:44 AM
redoregon's Avatar
Quoted: 2 Post(s)
Did you wash it or something?
redoregon is offline
The Following 3 Users Say Thank You to redoregon For This Useful Post:
a2jack (06-02-2011), Eddie19852004 (03-23-2013), HGB (01-20-2012)
Human Verification
331
Smart Key In The Washing Machine gryphon smart General Discussion 19 10-27-2009 11:04 AM
Washing a Smart chobocobo New Members Area 12 09-02-2009 02:44 PM
Whew! Smart Washing Red_Zippy smart General Discussion 26 05-14-2009 04:00 PM
Pampering Your Smart - Washing saronian smart Operation and Maintenance 34 09-09-2008 10:13 AM
Washing the Smart tee4 Mid-West Region 4 02-11-2008 09:34 AM
