I only drive my smart car in the winter, It is stored in a garage in the summer. After sitting for about a month i went to go start it up and the key slides down into the whole, but it won't turn. I thought i would try to figure out what the problem is but i can't.
So far:
-I checked all the fuses with a volt meter. (measured resistance)
-I checked the battery with a volt meter. (good)
-I disconnected the battery for 30 mins.
-I thought it could be the brake switch, So i replaced that. Still no luck
-I blew the key whole out with compressed air and lubed the key with some WD40. (it's currently 85 and sunny so it's not frozen.)
-I pushed the brake pedal down hard, shook the shifter and tried turning the key.
-I lifted the magical yellow switch and tried turning the key.
-I rocked the car back and forth from outside the car.
-I tried the spare key.
Can anyone suggest what i should look at next? The car is a 2009 passion.
Also when you turn the headlights on the car with the key out of the ignition, when you step on the brakes do your brake lights come on? mine are not.
Fuses should be measured for voltage, not resistance, and preferably while live.
A battery test result of "good" is of no use. A voltage reading is what is needed. How does anybody know if you know what is good or bad?
The key should turn whether the battery is dead or alive or somewhere in between.
The brake switch does not prevent the key from turning, it only controls the shifter interlock.
Anything liquid that is put into the key hole can get into the shifter housing where the shift control unit is located. The only thing that should be used to lubricate a lock cylinder is lock lubricant.
Try using a small hammer and a punch to tap around the lock cylinder while the key is gently wiggled left and right. It takes three hands. Find a helper or a mutant.
I assume you have tried BOTH sets of key's with no luck. It sounds like a mechanical problem with the innards of the key switch itself, as no electronic problem with the car can effect the turning of the key switch.
However, if I recall, the position of steering wheel can force it to bind up, so wiggle the wheel as as you try to turn the key.
Short of changing out the switch and having to go through a huge code change job, I would suggest bringing in a lock smith to look at it. Good luck. A2Jack.
I don't believe there is any relationship between the steering wheel and ignition key lock.
Somebody on here posted a problem like this some time back. If memory serves, there was debris in the key receptacle that prevented the key from being inserted fully. That can be a problem with the location of the ignition lock and the vertical key orientation. Try a strong vacuum over the key slot. If that's the problem, maybe the vac will suck it out. Hopefully the debris isn't packed in too tightly from repeated attempts to work the key.
I've had so many cars now, I lose track of which had locking steering wheels, but many did and they would interfere with the key switch when locked.
I no longer have my 08 Smart car, so I can't just run out and check it. However since it still goes by my house every day (sold it to a neighbor) I'll have look one day .LOL A2Jack
Drip a little lock deicer or isopropyl alcohol down the key hole. Dust etc., gets down there and sometimes gums up the works. I had a 2009 and this always works for me.
There is nothing electrical that can prevent the correct key from physically turning the ignition switch. All the electrical stuff happens when you go to position 1 and/or 2.
Be very careful so you don't compact whatever may be in there and jam it in beyond extraction. Perhaps a light lube, as described in in post 9, might be in order, and just work the key in and out.
Battery voltage was 12.23 which is normal I believe. Fuses won't give voltage readings since the car isn't on. I tried the twist/tap with hammer and had no luck. I tried vacuuming out the key whole before doing that.
I think I will have to take it into the dealer to fix. Anyone looking for a project? Willing to sell for cheap
Battery condition is totally unrelated to the key turning in the ignition lock.
The key will turn in the lock even if the battery is disconnected and removed from the car!
That is your problem, isn't it? That the key won't turn? :shrug:
Related Threads
Smart Car of America Forum
797K posts
63.7K members
Since 2002
