Knocking from wheel or brakes! Help! - Smart Car of America Forums : Smart Car Forum
Old 01-30-2009, 12:04 PM   #1 (permalink)
ADilwicius's Avatar
I have an appointment Monday but want the communities help if I can get it. Driving at any speed, when I let off the gas there is a loud knocking noise from I think my front left wheel... sounds to me like the caliper is loose and rattling but it's not... any ideas. the noise goes away if braking only does it on a roll with no acceleration!
ADilwicius is offline   Reply With Quote
Old 01-30-2009, 01:39 PM   #2 (permalink)
SmartDigger's Avatar
Sounds like a bad CV joint to me.
Could also be a cracked brake pad But, If brakes it would still do it under Acceleration
Old 01-30-2009, 01:42 PM   #3 (permalink)
If it's truly coming from the front it won't be a CV joint. No idea what it could be other than something inside the wheel well that hits the wheel under deceleration.
Old 01-30-2009, 04:37 PM   #4 (permalink)
more than likely one of the bolts are loose on the front shock/strut had a similiar noise when i installed springs didnt tighten a bolt fully
foyfarlow is offline   Reply With Quote
Old 02-04-2009, 10:06 AM   #5 (permalink)
Christoph's Avatar
actually, it sounds to me like a wheel weight is hitting the caliper. When you apply the brakes, the caliper is pulled inwards and away from the wheel spokes. Check the wheel weights on that side to see if there are any scrape marks on them. Hope that helps!
Christoph is offline   Reply With Quote
Brakes ASmartMan Dealers and Parts 9 07-14-2009 12:00 PM
Engine knocking- normal, or something wrong? rotary smart Operation and Maintenance 26 11-26-2008 11:13 PM
Squeaky brakes dcrooks smart Operation and Maintenance 3 07-08-2008 02:10 PM
New brakes Fredvon4 smart Operation and Maintenance 10 02-28-2008 02:16 PM
Bedding in new brakes Fredvon4 smart Operation and Maintenance 1 12-10-2007 06:04 PM
