Lift Points? - Smart Car of America Forums : Smart Car Forum
Old 01-26-2008, 09:14 PM   #1 (permalink)
doc540's Avatar
Lift Points?
Anyone know for sure or care to venture a guess as to where the lift points are for getting this thing in the air and over our heads?
Looks to have two behind the front wheels, but the back?
And no "sway bar/coat hanger" jokes!
doc540 is offline   Reply With Quote
Old 01-26-2008, 09:31 PM   #2 (permalink)
Carnut's Avatar
Well, I sure hope some aftermarket outfit comes out with a rub strip for the back tailgate and lights!
Hopefully the factory alarm they are installing will have a motion detector that will start the LOUD horn as soon as the car is starting to tip.
Old 01-27-2008, 12:34 AM   #3 (permalink)
Not Selling on Ebay
That's a 450. I think it's getting an oil change :-)
Old 01-27-2008, 04:18 AM   #4 (permalink)
Originally Posted by doc540 View Post
... And no "sway bar/coat hanger" jokes!
The "sway bar" is actually the DeDion tube. I have wondered how they fit it in; this is the first one I have seen that passed around AHEAD of the differential. Creative iteration of a very effective rear suspension design.
Old 01-27-2008, 08:04 AM   #5 (permalink)
Fredvon4's Avatar
fishrdnc... sorry your are partl correct... it is a DeDion variant...
However, look closley at the top of the tube... attached to the frame/tridion on either side are the anti sway links and at the front corners of the "tube" are the counter reaction points of the very light weight small diameter anit sway bar
The front attacment "piviot" point is a rubber isolator (bushing)... to firm these up significantly it can be resleeved with a polyurethane bushing
Caution- the already reported stiff ride will get significantly more harsh
add 35 series aspect ratio tires and the butt will get numb or bruised
Old 01-27-2008, 08:15 AM   #6 (permalink)
Yeah, it is a variant. Normally the DeDion tube is located laterally by a Watts linkage between the sides of the frame and the centerpoint of the tube. The linkage allows the whole tube to move up-and-down, but not side-to-side. The Caterham Seven also had a torsion bar along with the DeDion with adjustable pickup points to alter the suspension hardness (or softness).
And the smart is the only DeDion that I have seen that does not pass behind a chassis-mounted differential.
The semi-independent DeDion suspension had been the choice of front-engine, RWD racecar builders from the ’40 onward, both formula cars and sports/GTs. It only went out of common use with the advent of rear engine cars with transaxles located behind the engine (no room for the DeDion tube, but plenty of room for long-“A arm†fully-independant). Porsche never used it; they used a swing axle instead.
The design has three distinct advantages: it will accommodate a tremendous amount of torque and stress for its mass; it reduces a lot of un-sprung weight at the wheels; it keeps the rear wheels vertical regardless of body lean or suspension travel (no negative camber needed). The smart DeDion looks relatively massive, but its tube does have to pass around forward both the transaxle and engine, not just behind a differential.
I assume that DeDion was chosen for the smart because there wasn’t sufficient room for the lateral “A-arms†used in a fully independent suspension.
Old 01-27-2008, 08:15 AM   #7 (permalink)
looks like it is sitting on two tow hooks wonder what is behind this shot.
also wonder how hard it is to drop the powertain cradle. nice belly pan.
Old 01-27-2008, 09:07 AM   #8 (permalink)
Senior Smartie
jonnysan's Avatar
Enlarging that sway bar....
Would seem to be fairly easy to do if one wanted to take away some lean. It would not affect ride too much either. Have to consider that once I see how the car really handles once I have mine (MAYBE....this week?)
John
Old 01-27-2008, 09:37 AM   #9 (permalink)
Enlarging the sway bar....
Don't you get those enlargement e-mails?
Old 01-27-2008, 10:03 AM   #10 (permalink)
doc540's Avatar
OK, I set up my own thread for hijack by posting a joke about the sway bar (and I know a sway bar when I bend one).
Back to the question for all you gearheads: does anyone know for sure how the car's to be lifted?
(And I can't wait to get under there and sniff around.)
Lift kit for a fortwo roverallover smart Gallery 9 11-21-2007 11:49 PM
