Jet Fuel, what do you look like sans cravat? Also, the hardwire lead that comes with the battery charger I described has a fuse on the positive side & ring terminals on each end to connect to the battery terminal bolts. The positive terminal is labeled so that you will not reverse the polarity. The battery Tender charger cable, I think, is not fused but has a + sign to identify the positive lead. Both have a connector so you can un-plug the alligator clip leads and plug into the hardwire adapter.
