I noticed something was off with my car last night when I clicked my keyfob to unlock my car twice. The first time my upper rear lights flashed, and the second time, only the left one flashed. I thought I'd blown a bulb, so I had my wife look at the brake lights as I put my foot on the break, and she said that while both the upper ones remained on (it was night so my headlights were on), the lower ones (the brake lights) did not go on. She knew I was hitting the brake because the bar light on the top of the rear window was working. I then started driving, and I noticed the following symptoms (including those above):
-Brake lights don't work except for top bar
-When I use my key fob, only the left rear light flashes (even though when the headlights are on, both lights work)
-If i put my turn signal on to the left, it is normal, but if I put my turn signal to the right, it goes at double-speed
Does anyone know what this might be? I'm planning on taking her into the dealer next week sometime, but if its as simple as a specific fuse that might save me some time.
Thanks!
Carl
