Locking without the three beeps - Page 2 - Smart Car of America Forums : Smart Car Forum
Old 08-04-2008, 04:03 PM   #11 (permalink)
Originally Posted by tjmodz View Post
I think you only get beeps if you have the factory alarm?????
yes that is true
wdw412 is offline   Reply With Quote
Old 08-04-2008, 04:24 PM   #12 (permalink)
skyzdlimit59's Avatar
Thanks tjmodz, mystery solved.
Old 08-04-2008, 09:52 PM   #13 (permalink)
No problem. Glad that I could help.
And that I finally got something right.
tjmodz is offline   Reply With Quote
Old 08-25-2008, 07:40 PM   #14 (permalink)
My 2000 forTwo Cabrio used to flash three times when I locked the doors...now, it waits about 20 seconds, then flashes about 100 times! After about 20 seconds, it flashes 100 more times...anyone have any ideas? I have closed and reclosed all the doors numerous times...but no change.
John_in_CCTX is offline   Reply With Quote
Old 08-25-2008, 07:44 PM   #15 (permalink)
Admin/Mod.
Try to use the second key. Numerous flash from the car can be a symptom of a weak battery in the fob.
Old 10-21-2008, 06:09 PM   #16 (permalink)
Old SGM's Avatar
Several times my UFO beeped and locked the car while in the garage, I though maybe the key fob button stuck out too far and somehow I activated the lock button. Once I left the car in the garage, with the widows down, and the thing activated the alarm. The next morning at 05:30 I tried the door it would not open, so I reached inside and opened the door. Well I found out the alarm work very good and loud. I also found out you cannot turn off the alarm with the key fob. I had to start the car before the alarm went off. I probably woke up several late riser neighbors.
Last weekend I was working in the yard and UFO beeped, lights flashed for more than the normal 3 times, I did not have the key with me so I had to run in the house to get the keys, by the time I got back to UFO, the beeping and flashing had stopped. Since I live near an airport, I thought maybe a stray radio or radar signal has set the the alarm. I have had UFO 6 months and I am still being amazed with it's gimmicks and quirks.
Old 10-21-2008, 08:16 PM   #17 (permalink)
Admin/Mod.
Originally Posted by Old SGM View Post
[...] I found out the alarm work very good and loud. I also found out you cannot turn off the alarm with the key fob. I had to start the car before the alarm went off. I probably woke up several late riser neighbors.[...]
During a smart gathering near the Pentagon, I purposefully left a window open, locked the car and, several minutes later, reached for a cup in the cup holder: the loud alarm went off, and I did silenced it using the fob.
From the Owner's Manual:
Cancelling the alarm
> Insert the key in the starter switch
> Turn starter switch in position 1
or
> Press button "lock" or "unlock" on the key.
page 78
Old 11-18-2008, 04:22 PM   #18 (permalink)
Can anyone tell me the location of the device that emits the (offensive) beeps when the alarm is set? I've searched and searched. GOT TO DISABLE IT.
bjordan is offline   Reply With Quote
Old 11-18-2008, 04:58 PM   #19 (permalink)
Chances are if you disable the beeps you will disable the actual alarm.
Old 11-19-2008, 02:06 PM   #20 (permalink)
Maybe, but I don't think so. Posters have said the actual alarm is from a different source, not from the beeping device. I any event, my thought is to place resistence in line with the voltage source, thus reducing the audio level.
Either way, even if the alarm and the annunciator are the same, it must have differing inputs for the two functions. I would work only with the annunciator.
Where's the Beeps? KingNine smart Operation and Maintenance 2 04-13-2008 05:03 PM
Locking the car without the key skyzdlimit59 smart fortwo (451 - US vehicle) 16 03-06-2008 11:39 AM
Locking Gas Cap jediknight36 smart General Discussion 3 02-05-2008 10:49 AM
