I received an email from a respected vendor who's offering Dimple brand magnetic oil drain plugs and Dimple brand magnets that you put on your oil filter. Both items are reusable and are supposed to trap metal particles that would otherwise escape the filter. When you change the oil, you're supposed to wipe these fragments off the plug and re-install it. The magnets that go on the outside of the filter are supposed to trap fragments against the filter case. Again, after you change the filter, you put the magnets on the new filter you're installing.
Does anyone have any experience/knowledge of whether these actually work or is it just wishful thinking and good marketing?
...they do the job that they were intended for...big engines have the magnetic plug wired to a light to let you know that there's something going on..the manufacturer calls them "chip" light...we call them "chunk" light for a reason...
Thank you jwight, I've been meaning to ask that question too. What is the function of the screen on the oil plug/pickup? There's already a filter in the system, so is it redundant filtration protection or something else?
Thanks, a pre-filter was all I could make of it too. So, does that mean that if we're concerned about ferrous metal filings, as in Jetfuel's crankshaft example, does the magnetic drain plug serve this purpose and make the screen redundant and unnecessary?
Reason: clarify, I hope
The screen is aparantly exactly as stated... a pre-filter. I think it is logical that it ONLY does its job at two specific times in the life of your engine. First, when the engine is started for the very first time where there may be filings in the sump that hasn't had a chance to go through the (much finer) oil filter. Second, the instant your engine blows up and you have bigger problems to worry about.
For the 200,000+ miles in between... I can't see how such a course filter would do anything at all.
Now, do the magnets? According to the manufacturer they absolutely do. I obviously can't personally back that claim as I have no data either way. I think logic would say it helps and certainly couldn't hurt.
To answer the Q about the screen directly: No, it does not come with a screen. Yes, your original screen can be re-fitted onto the magnet. However... the longer thread of the replacement plug makes it so it won't fit. So you'd either have to use some washers to make up the gap (not sure how well that would work) or you'd have to carefully trim the screen to account for the difference.
However I certainly didn't bother in my car. And when I had mine installed, it was by the dealership and they raised no question at all. There was no discussion about the screen or concern in the slightest. That was the first time I knew about the screen... when they handed my original back to me. I asked if that was important, and the service manager shrugged is shoulders and said simply, "not really".
Obviously it is up to the individual to decide. I can't monitor the forums constantly so if someone does come up with a factual determination (ie. some service manager somewhere says not to do it) then please, I'd appreciate if someone can give me a headsup. It is a new product at my store and it seemed like a good, or at least harmless, thing to try and by all logic it should help prolong your engine's life.
